Citroen C2 1.1 60HP Engine: Stuck at 2500 RPM, Waving Revs - Replaced Candles, Coil & More
krzysieksivy 8742 17
Why does my Citroen C2 1.1 60HP idle normally but stop at about 2500 RPM and start wavering under throttle after I have already replaced the plugs, coil, lambda probe, throttle body and crank sensor?
The most likely causes are a weak fuel supply under load, damaged wiring/connectors at the engine sensors, or a blocked exhaust/catalyst; the immobilizer is unlikely because it usually prevents starting or makes the engine die after a second [#16296030][#16296143][#16298588][#16298633] Check the sensor plugs and wiring to the ECU because broken wires in the connectors can cause strange running even with no fault codes [#16296030] Try unplugging the coolant temperature sensor as a test and see whether the behavior changes, because a bad temperature signal can make the mixture wrong [#16296143] Also verify fuel pressure on the injection rail, not only at the pump outlet, because a pump can show about 3.5 bar at the supply line yet still fail under load [#16296143][#16296388] If the pressure is OK, inspect the intake for leaks and consider a blocked exhaust/catalyst as another cause of the 2500 RPM limit [#16298588][#16298633]
  • #1 16295995
    krzysieksivy
    Hello, I have a Citroen C2 with a 1.1 60HP engine.
    The problem is that the car fires normally but when adding gas it reaches 2500 and it does not go any further and the revs start to wave.
    I have already replaced the candles, the ignition coil, the lambda probe, throttles, the shaft position sensor and the gas passed and then the same, I do not know what maybe someone has some ideas, I'm waiting for a reply.
  • #2 16296007
    rafcio_21
    Help: 137
    Rate: 299
    Check the driver maybe some cold February are. What errors shows when connected to a computer.
  • #3 16296028
    krzysieksivy
    Zero errors on the computer.
    Which drivers are you talking about?
  • #4 16296030
    rafcio_21
    Help: 137
    Rate: 299
    The engine controller check the cubes at the sensors - the wires in the cubes are often damaged
  • #5 16296042
    krzysieksivy
    I'm gonna go check.
    But I don't understand why it runs normally at idle speed.
    And which of the sensors determines the dose of fuel and air?
  • #6 16296069
    rafcio_21
    Help: 137
    Rate: 299
    The lambda probe on the exhaust manifold can only work in the low speed range and at higher revs it shows a lean mixture and the controller then doses more fuel or the coolant temperature sensor may be damaged and the engine gets more fuel
  • #7 16296075
    krzysieksivy
    This may be possible because there is fuel smell from the muffler
  • #8 16296094
    rafcio_21
    Help: 137
    Rate: 299
    Check how many wires the probe has and what colors, then I will tell you how to measure it with a multimeter.
  • #9 16296117
    krzysieksivy
    The probe on the intake manifold - green plug
    Green orange white yellow
    Probe behind the catalyst - blue plug
    Gray brown white green
  • #10 16296143
    rafcio_21
    Help: 137
    Rate: 299
    I am not sure because these colors are a bit strange, but I bet the color green. Yes . For a test, try unplugging the plug from the temperature sensor and fire up if something changes
    Added after 11 [minutes]:
    One more thing comes to mind if you do not have a dirty fuel filter, maybe your fuel pump ends its life and does not give enough pressure and at idle speed is ok, and the higher pressure is too low and injections instead of dosing with fuel
  • #11 16296293
    krzysieksivy
    There is no fuel filter and the pump gives 3.5 bar.
    What do you think about the carbon filter?
  • #12 16296388
    rafcio_21
    Help: 137
    Rate: 299
    Rather, it should not have such a big effect, and the pressure you write is at the pump outlet or on the injection rail.
  • #13 16296398
    krzysieksivy
    On the supply hose at the strip
    Added after 1 [hours] 24 [minutes]:
    I checked everything on the poll.
    Nothing else comes to mind.
    Added after 41 [minutes]:
    Tell me what you think about the immobilizer because I heard that these models have immo so that it will smoke anyway
  • #14 16298588
    rafcio_21
    Help: 137
    Rate: 299
    Usually like imo. it is blocked, it does not start at all or it will fire and go out after about a second. Anyway, it does not indicate any error, it should be ok. And a colleague checked for any leaks in the intake manifold.
  • #15 16298633
    mod22
    Help: 130
    Rate: 312
    Or maybe the exhaust is blocked?
  • #16 17708419
    Kaczamil
    Hello. Was it possible to locate the fault. I have exactly the same symptoms. I would be grateful for the tip. best regards
  • #17 18488299
    bulibulew
    Hi . I have exactly the same problem as the car is jammed at 2500 RPM and it will not go further, but I get an error: antipollution system also, most likely, the catalyst and filters, etc., would have to be changed
  • #18 18488410
    Kaczamil
    A year ago I had this problem. 2.5 thousand revolutions and cut off the fuel, it jerked.
    I did not mechanically repair anything.
    I poured the fuel conditioner, poured over 98 gasoline and stopped refueling at cheap stations. After 3 days, the car repaired itself and this defect did not appear.
    best regards
The discussion revolves around a Citroen C2 with a 1.1 60HP engine experiencing a problem where the engine revs are stuck at 2500 RPM and fluctuate when accelerating. The owner has replaced several components including spark plugs, ignition coil, lambda probe, throttle, and position sensor, yet the issue persists. Suggestions from other users include checking for damaged wiring in the engine controller, assessing the lambda probe's functionality, and considering the coolant temperature sensor's impact on fuel mixture. There are also mentions of potential issues with the fuel pump, carbon filter, immobilizer, and exhaust blockage. Some users shared similar experiences, with one noting that using high-quality fuel and a fuel conditioner resolved their issue.
