Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026
mkaminski100 75645 41
Why does my Citroën C4 2.0 HDi run unevenly and show injector balance faults P0266/P0269/P0272, and what should I check first?
This fault should be approached first as an injector/fuel-system or one-cylinder compression problem, not as an EGR/DPF problem, so the key checks are injector leak-back/overflow, injector wiring and supply, fuel pressure, and a compression test on the suspect cylinder [#15741073][#15741987][#15743703] At idle alone the live data is not enough; the advice was to log parameters under load/while driving, because the rail pressure and correction values there reveal problems that are hidden at standstill [#15741073] If the injector fault stays on cylinder 4 after swapping injectors, then the problem likely follows the cylinder or its wiring, so check compression and the rubbed harness/connector for that injector [#15743703] The later update from the thread says the car was finally fixed by replacing the pump and injectors, and the removed pump showed sediment/rust-like contamination inside [#15801884]
  • #1 15740494
    mkaminski100
    Help: 7
    Rate: 227
    I just got a C4 Hdi after 3 years of Citroen's intervention and (as the owner claims) replacing half of the car (turbo, pump, dual mass, sensors, etc.).
    The engine works very unevenly, and after resetting all the codes, only those from the injectors and the temperature sensor are repeated. (checked with DiagBox)
    The injections are clearly out of calibration (link to readings below), but strangely it starts with the first one and gets worse until the fourth.
    The car does not smoke, the exhaust pipe is clean. The DPF is definitely working because the exhaust is clean
    I'm considering injections, but I doubt that as many as 4 will fail.
    Errors that occur constantly are:
    P0266 - Cylinder 2 - contribution/balance error
    P0269 - Cylinder 3 - contribution/balance error
    P0272 - Cylinder 4 - contribution/balance error
    P0098 - Temperature signal on the collector
    Before the reset, there were no sensor codes or pressure on the rail.
    At the beginning, I took into account breaking the belt and repairing it at Lemon and Gumiak, but then (most often) the calibration of one injection breaks down.
    I'm also thinking about the shifted valve timing, but before I get to it, I'd like to check the less invasive elements.
    And of course I will check the EGR, although its damage would be detected here and ... possible damage to the beam.
    I will be very grateful for any hints
    Link to print with errors:
    https://drive.google.com/file/d/0B_egWe7F0sL-NWUzWExtUmhkQjA/view?usp=sharing
  • #2 15740718
    domex32
    Help: 585
    Rate: 2451
    Pull out the glow plugs and check that they are all intact and that the pin has not come off.
    What's your max differential pressure under load?
    Swap the first injection with the fourth and see if the balance balances will change together with the injections, then it will turn out whether it is the injectors' fault.
  • #3 15740742
    mkaminski100
    Help: 7
    Rate: 227
    Access to candles in C4 is sticky, because the engine is at an angle, so for now I have removed the pit and I am replacing the injections. If after the swap it will still be 4 bad, it's something with the cylinder. Injectors clean, no blow-by.
    Then, as I deal with it, I will unscrew the candles (resistance first). Do you think she broke down and did damage?
    It's hard to check under load, because the car barely moves and I had a problem getting it into the garage.
    I can already see that there are plenty of bands everywhere and the plastic cover of the EGR mechanism is on the engine and the EGR has a cover on, so it turns out that the parts have been changed.
    Thanks for the answer
  • #4 15741073
  • #5 15741385
    mkaminski100
    Help: 7
    Rate: 227
    I agree and I know I should have spent more time diagnosing first. I have the car since yesterday and for now I wanted to see the engine physically in terms of damage and confirmation of the replacement of components.
    The engine starts without problems and almost immediately starts to work very unevenly. It does not smoke, the exhaust pipe indicates the correct operation of the DPF.
    It works badly at all revs and enters the revs quite badly.
    Often there is a problem with starting and driving as if the engine was working on 2-3 cylinders.
    After warming up, it is often better, but as I have noticed, even after turning off and restarting the engine works a little better.
    Today I will try to swap injections 1 and 4 and see if error 4 will move or not. Then I will immediately check the rest of the engine parameters and post.
    I noticed a slightly rubbed wire of the harness (it was wiped by the engine cover) and I wonder if sometimes a puncture on the injection cable will not cause such revelations. I do not remember the injection voltage exactly, but it is probably around 100V, so there is a chance of jumping a spark.
  • #6 15741434
  • #7 15741443
    domex32
    Help: 585
    Rate: 2451
    Check the egr valve. The fact that the pipe is clean may also indicate that the filter is clogged and the exhaust gases under high pressure go to the egr. That's why I asked about differential pressure.
  • #8 15741574
    mkaminski100
    Help: 7
    Rate: 227
    The injectors are definitely Siemens (Conti) and piezoelectric to my knowledge.
    The engine computer has no stamped date, but it has a Conti badge, so since Continental took over Siemens, probably in 2007, the computer is probably new.
    Unfortunately, I do not have such equipment given in the thread, and in the UK the use of someone who has it will probably exceed the value of the car. So I was thinking of using a Megger meter and connecting to the cable itself, disconnected at both ends.
    I'm definitely going for the EGR. According to the owner, it was replaced and I found a mechanism cover on the engine, so something was combined. The engine in the C4 is at a considerable angle, so even after removing the battery and the pit, access is very poor.
    According to the computer, there were no DPF errors (which was supposedly also mentioned - I'll check today), but I'll check the differential pressures today and give it together with other parameters.
  • #9 15741987
  • #10 15742910
    mkaminski100
    Help: 7
    Rate: 227
    I checked the EGR electronically and there are no errors. It ticks as it should.
    I swapped injection 1 and 4 and now error 4 has disappeared, but error P1195 (open injection) appeared, only it does not specify which one.
    I attach scans from engine operation after replacing injections 1 and 4.
    Looking at the injections, it turns out that correction 4 is now the best, but I did not do it to compare the parameters before the replacement.
    According to the computer, the DPF is regenerating, but the can itself is lukewarm, so I don't really believe it.
    I'd be very grateful for pointers.
    • c4 injectors.pdf (314.35 KB) You must be logged in to download this attachment.
    • c4 injectors 2000revs.pdf (314.34 KB) You must be logged in to download this attachment.
    • c4 injectors 3.pdf (314.35 KB) You must be logged in to download this attachment.
    • c4 errors.pdf (331.37 KB) You must be logged in to download this attachment.
    • c4 dpf.pdf (338.78 KB) You must be logged in to download this attachment.
    • c4 injectors 2.pdf (314.35 KB) You must be logged in to download this attachment.
  • #11 15743111
  • #12 15743165
    domex32
    Help: 585
    Rate: 2451
    When checking the overflows, do not forget to maintain a constant pressure on the overflow of at least 2 bar, otherwise the injection will not work properly.
    Be sure to check the compression pressure, with a dose of 16mg/H and an injection time of over 4.5ms, the pistons could flow.
    To be sure, unseal the intake as close as possible to the engine, e.g. by removing the air intake pipe, and for these tests, disconnect the plug from the flow meter and EGR, write whether the fuel dose and injection time have changed.
  • #13 15743326
    mkaminski100
    Help: 7
    Rate: 227
    I couldn't do the overflow tests today, because I have to make extra wires, but I'll try tomorrow.
    update.
    I just checked the parameters again and the injection error on cylinder 4 returned, which would indicate a problem with the cylinder.
    I know that these are just errors at a standstill, but the parameters of the doses of the first cylinder are almost perfect (100%), and the rest are moving.
    The second drops to 60% and the third and fourth goes well over 100%, but the fourth is the strongest.
    I'm waiting for a compression tester and will try to check it out.
    Do I remember correctly that French cylinders are counted from the chest?
  • #14 15743703
  • #15 15743901
    mkaminski100
    Help: 7
    Rate: 227
    Thank you for your answer.
    I disagree with your opinion on help. Like you, I work and I take care of this car for about an hour a day, so I have very limited time.
    Sienens - Conti injectors are not coded so they can be interchanged. Even in some screen from DiagBox there is information about the inability to encode them. I've already replaced a lot of them so I care about cleanliness and I know what the voltages are there.
    1. I did not do the overflow test because, as I wrote, I do not have extra hoses. These injections have quite difficult access and you have to either put on plugs that are tragic to insert and often break, or put on hoses that I don't have yet (mine are too hard and I've already broken the connector once).
    2. Power supply as much as I could check. The worn cable is from the second injection. Couldn't do it any more without disassembling all the handles.
    I will not check these cables with Megger, because I would have to check every cable that goes in the bundle, and I do not have the correct current values for the oscilloscope. Anyway, I can have an oscilloscope, but next week.
    3. Compression - That's why I asked about the cylinders, and the device is on its way. There is reasonable access to candles in the 4th, 3rd and 2nd cylinders (I checked yesterday), so it's enough to compare these 3 values. Unfortunately, my pressure gauge is calibrated for petrol, so I'm waiting for one for diesel and I'll check it over the weekend.
    4. As I wrote, the car hardly drives, and the owner has deregistered it, so I can't really move on a public road. Well, as you have seen, the correction parameters for each injection are 100% when adding gas. At 3000rpm, the pressures seem fine to me. I'm also afraid to drive something like this because I've already chosen it like that once and it turned out that the previous owner had moved the belt on the left bank of cylinders and the piston was closing the valves until the poppet broke off during my drive and the engine needed to be replaced. That's why I wanted to check the timing.
    5. According to me, there was something, but after pouring it on paper, I don't see anything disturbing. But I didn't have enough fuel to collect it and throw it under the magnifying glass, because I can't see anything with the naked eye. In addition, I checked the pump, which was not replaced, so I have to look at it too.
    However, I think that after replacing the injections and the problem that remained on cylinder 4, I have to focus on it.
    So it's not like I'm scheming without anyone's help, but having only a moment I try to do what I can finish in one day and at least exclude these elements. Advice is very helpful, but I am also asking for understanding and patience, because there is no time.
    In addition, I do it myself, so I also have a limited workshop and not everything at hand.
    Domex - I didn't notice your entire post. I will try to do that today.
  • #16 15744540
  • #17 15744607
    mkaminski100
    Help: 7
    Rate: 227
    I don't think the tone was offensive, but I also know that it's just a text and everyone can take it in their own way, so I just confirmed that I'm not doing it my way.
    In DiagBox I did not find any data on the calibration of these injections, but I will look again. I honestly admit that the difference between a saved injection and a non-saved one, even where it is saved (eg Delphi) is minimal, certainly not such that the engine works unevenly. We can rule that out.
    Regarding compression, I'm talking about piston compression, because I suspect a lack on cylinder 4.
    The plugs in these engines are not ceramic, i.e. they probably have a ceramic insert, but the plug itself is standard. I've had a lot of these engines out and never had any problems. I want access to the spark plugs to check the compression in the cylinder.
    You can write more about the method of measuring compression that you gave because it is interesting.
    As for the timing shift, I haven't seen it, but I've heard of diesels that worked on the shifted one, although I doubt it here. However, I know a few cases when, after an incorrect replacement, the piston bends the valve cone, which does not close, causing a pressure drop. Then the "injection" action began because the codes pointed to them.
    In this engine, the shaft sensor is on a magnetic pad under the pulley and this one can be moved. I have not come across this case personally.
    When it comes to filings, it is easiest to check the filter can in this engine, because it is plastic, which I will be doing soon. I just don't remember if sometimes the return from the injections doesn't go directly to the fuel tank.
    Unfortunately, the injector test denies problems with the injections, but I'll check anyway, because I've already driven it a few times.
  • #18 15746650
  • #20 15748047
    domex32
    Help: 585
    Rate: 2451
    Let me have a different opinion as to the professionalism of such measurements, in the new engine it makes sense, but here, in engines with a certain mileage, there are several components of the variables that make up the measurement. Among other things, the wear of the starter gear, flywheel rim, dual-mass flywheel, clutch bearing, clutch shaft bearing, CR pump operation, timing belt ripple, pk belt and accessories, wear of bushings, pistons, connecting rods, heads, etc. And bosch will always find a device and way to market effectively. A whole lot of equipment for measuring the injector current can be replaced with a tester and check the cylinder balance.
    In a word, bypassing marketing, the best measurement is pressure measurement with a manometer, cheaper, faster and more effective.
  • #21 15748111
    mkaminski100
    Help: 7
    Rate: 227
    Today I managed only a little, because I forgot that the candles are nicely hidden behind the EGR cooler, and additionally the wires are screwed with a tiny nut, not pressed in.
    I took out the EGR and it looks fine. I haven't removed the EGR cooler yet, so I can measure the pressure tomorrow.
    However, I checked the fuel filter and there are no filings, but there is a slight rusty coating and the filter is slightly covered with it. I'm a bit surprised by this, because in the absence of filings, it turns out that the sediment comes from the gas station tank.
    To be continued.
    Regarding diagnostics with an oscilloscope, this is quite an interesting channel here. It's a bit beyond me, especially since, as you will notice, without knowing the exact values of the parameters, these graphs do not give anything. For example, in the case of turbo diagnostics, the control at the level of 83% was 3% too much, which caused an error. Without this knowledge, looking at the chart will not show anything.
    https://www.youtube.com/channel/UC3hbk2hjhVXFUFBalfmPG3g
  • #22 15748219
  • #23 15750294
    mkaminski100
    Help: 7
    Rate: 227
    I checked the compression today. It comes out after about 24-25 bar on each cylinder, so it's almost like a funk leg, unmistakable.
    Now it's time for injections. The whole engine with injections and the pump is already going to me, so I will replace.
  • #24 15750313
    domex32
    Help: 585
    Rate: 2451
    25 is the minimum, 28-30 bar should hold.
  • #25 15750340
    mkaminski100
    Help: 7
    Rate: 227
    According to Haynes, this engine is supposed to have 20bar + - 5 for heat Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026
  • #26 15750364
    domex32
    Help: 585
    Rate: 2451
    You're right, they heavily depressurized this engine for RHR, you gave the correct pressure, I gave the pressure for RHY :)
    In that case, you have a set of injectors to start with the spacer.
    Stay clean during this process so you don't mess up your injections.
  • #27 15750385
    mkaminski100
    Help: 7
    Rate: 227
    I checked with Autodata to be sure and it's 15 to 25.
    Thanks. Unfortunately, it is very difficult to keep super clean, especially when replacing with used ones.
    And I noticed that a quite large metal needle, 2-3 mm long, can often chip off the head of the tube.
    For now, I will put everything together and unscrew the pump to check what it looks like.
    Thanks everyone for your help.
    I see.
    I forgot to write that there is very little of this sediment in the filter and it is powder
    Attached are the photos I took in the filter
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160617_185259_HDR.jpg (1.51 MB) You must be logged in to download this attachment.
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160617_185306_HDR.jpg (1.33 MB) You must be logged in to download this attachment.
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160617_185318.jpg (1.47 MB) You must be logged in to download this attachment.
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160617_185324.jpg (5.88 MB) You must be logged in to download this attachment.
  • #28 15750587
  • Tank contains resin-like plastic debris, not metal filings
    #29 15770354
    mkaminski100
    Help: 7
    Rate: 227
    I don't agree with the huge numbers. First of all, the return from the injection in this engine goes to the tank, not the filter, so the filings do not mean much. In addition, there are no filings in the filter, only garbage. Nothing in the filter is magnetic, and pump debris is magnetic.
    Anyway, I checked the tank and there are no filings at the bottom, but there is something resembling resins or glue, which was very difficult to remove.
    the tank and the basket are already washed with extraction gasoline, which dissolves this deposit at least a little (crude oil dissolves it very poorly, as does brake disc cleaning fluid), but I'm wondering what to use to rinse the pump.
    I will rinse the pump with gasoline and maybe make injections to clean it, because I suspect that this may be the reason for poor work.
    Maybe tomorrow I'll be able to do something and post some more pictures.
    I just wanted to clarify that the white bits on the rag look like plastic and are not metal, so there are no metal filings in the tank.
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160624_211258.jpg (2.23 MB) You must be logged in to download this attachment.
    • Citroen C4 2.0 HDI - uneven engine operation. Injections out of calibration P026 20160624_211303.jpg (1.63 MB) You must be logged in to download this attachment.
  • #30 15770415
    domex32
    Help: 585
    Rate: 2451
    It's ginger, it's urea, a fap additive :-)
Discussion of a Citroën C4 2.0 HDi with very uneven engine running, repeated injector contribution/balance faults (P0266, P0269, P0272) and a temperature signal fault (P0098). The engine starts but runs badly at all speeds, with no smoke and a working DPF/FAP. Diagnostic steps included checking EGR operation, swapping injectors 1 and 4, inspecting injector wiring for abrasion, measuring compression, and examining fuel filter, tank, pump, and injectors for contamination. Swapping injectors moved the fault behavior, but compression on all cylinders was only about 24–25 bar, below the expected range, and there was evidence of rust-like sediment in the fuel system. The final resolution was replacing the injectors and high-pressure pump with a complete used engine set, after which the car started and ran correctly.
TL;DR: 80 V/20 A piezo-pulse, 25 bar cylinder pressure shows healthy DW10BTED4 compression — “Injector stuck open can melt a piston” [Elektroda, Anonymous, post #15741987]
Why it matters: Correctly reading P0266-P0272 misfire data prevents costly engine and DPF damage.
• Compression spec: 20–25 bar hot, equal within 3 bar [Haynes via Elekt, mkaminski100, #15750340] • Injector current & voltage at fire-up: 20 A / 80 V [Elektroda, Anonymous, post #15741434] • Acceptable injector correction: ±3 mg/stroke (limit ±5) [Elektroda, domex32, post #15789677] • Overflow test fail: >50 % difference vs. best cylinder [Elektroda, Anonymous, post #15787920] • Piezo plug live voltage: up to 250 V – never unplug at idle [Elektroda, Anonymous, post #15741434]
What really causes the P0266, P0269 and P0272 “contribution/balance” errors on a 2.0 HDI?
They appear when cylinder-specific fuel delivery drifts outside ECU limits. Main triggers are leaky control valves (large overflow), wiring chafe on the twisted pairs, or clogged return lines that drop rail pressure [Elektroda, Anonymous, post #15741073]
Is 24–25 bar compression good for the DW10BTED4?
Yes. Hot readings of 24–25 bar fall inside the 20 ± 5 bar factory window, indicating rings, valves and gasket seal properly [Elektroda, mkaminski100, post #15750294]
What does code P1195 mean on this engine?
P1195 = injector electrically commanded but hydraulically stuck open. Continuous injection can wash bores and burn pistons within minutes [Elektroda, Anonymous, post #15743111]
Do Siemens/Continental piezo injectors need coding after swapping?
No. Third-generation Siemens piezos on DW10BTED4 are non-coded; ECU recognises them automatically [Elektroda, mkaminski100, post #15743901]
Safe compression test without removing injectors – possible?
Yes. Use the starter-current drop method: clamp an amp probe on the starter lead, disable fueling, crank 5 s and watch the oscilloscope; equal current peaks mean equal compression [Elektroda, Anonymous, post #15746650]
Does EGR or DPF clogging create harsh misfire at idle?
Rarely. EGR or FAP restriction adds smoke and power loss, but pronounced shudder at all revs almost always traces to injection issues, not the exhaust side [Elektroda, Anonymous, post #15743703]
Why keep a constant 2 bar during the leak-off test?
Piezo injectors require controlled back-pressure; open returns let them mis-meter, giving false pass/fail results [Elektroda, domex32, post #15743165]
What does ‘power share/balance’ 0.96–1.03 mean in a Ford 2.0 TDCi scan?
Values between 0.7 and 1.3 (±3 mg/stroke) are normal; correction limit is ±5. Your 0.96–1.03 range signals healthy injectors [Elektroda, domex32, post #15789677]
Edge case: what happens if I unplug a piezo injector with engine running?
The valve can freeze open, causing full-time fuel flow that destroys the piston — a “don’t ever try it” scenario [Elektroda, Anonymous, post #15741987]
Metallic or rusty powder in the fuel filter – dangerous?
Yes. Even teaspoon amounts suggest pump or injector wear. Flush tank, lines, regulators and add 1:100 2-stroke oil for lubricity before more diagnostics [Elektroda, Anonymous, post #15750587]
Quick 3-step procedure to verify wiring faults on injector pairs?
  1. Visually inspect twisted-pair insulation, especially where the cover rubs [Elektroda, mkaminski100, post #15741385] 2. Wiggle harness while idling; if correction jumps, suspect a break. 3. Measure continuity end-to-end; resistance must equal zero ±0.1 Ω.
