[Solved] Ford Transit 2.0 Won't Start: Fuel Pump, Fuel Filter, Battery, Injection - Possible Causes
Robcio1980 24120 12
Why does my Ford Transit only start after I loosen an injection pipe, and then fail to start again when it cools down?
The most likely cause is air entering the fuel system or fuel draining back to the tank, so the engine has to be bled before it will start [#16359389] Check for leaks in the injector overflow lines, injector pipes, injection pump, and filter mount, because even a small leak can let the system lose its prime [#16356441][#16359389] A common fault is worn valves in the mechanical feed pump, which can still pump while running but let fuel flow back when the engine is off [#16359389] Replace the lift pump with a decent quality unit, not the cheapest one, and inspect whether the pump itself is dry or leaking [#16359389] Also redo the fuel filter installation carefully: clean the sealing surface, oil the gasket, and fill the filter with fuel before fitting it [#16359389]
  • #1 16297944
    Robcio1980
    Rate: 11
    I have a problem with Ford Transit
    Earlier, it fired easily even in severe frosts.
    Some time ago, after stopping, the car went out and did not want to start again
    The battery is new, all cables are whole, I've changed the fuel filter but I still don't want to fire
    Recently, I tried to check if the pump feeds fuel after unscrewing one of them and turning the key, you can see that the fuel flies without a problem and here is the puzzle, after screwing the injection pipe I turned the key and the car fired without a problem.
    It came for some time, the engine was warmed up so I turned it off, I tried to start it again, it started after a long mole.
    Unfortunately, as the engine cooled down, it was not possible to start it, so I tried again to unscrew the injection tube and the car started again
    What could be the reason that I can't start the engine?
  • #2 16298054
    andrzej20001
    Help: 1578
    Rate: 6678
    The layout is announced
  • #3 16298064
    Robcio1980
    Rate: 11
    In that case, how to bleed the system so that it does not get aerated?
  • #4 16298070
    andrzej20001
    Help: 1578
    Rate: 6678
    Eliminate leaks.
  • #5 16354699
    Robcio1980
    Rate: 11
    The leak has already been removed, the ford started to fire but not so immediately. After turning the key the engine does not start immediately, only a few press of the gas pedal feeds with the car fires. After firing the car works fine. press the gas to make the car surprise. What could be the reason that pressing the gas pedal helps start the car and I don't want to
  • #6 16355009
    Megawe
    Help: 246
    Rate: 1445
    Temperature sensor.
  • #7 16355509
    Robcio1980
    Rate: 11
    And where is the temperature sensor?
  • #8 16356441
    wojciechjanusz
    Help: 97
    Rate: 465
    In my opinion, it is still slightly aerated. Check the injection overflow lines.
    What Transit is it - tddi or tdci?
  • #9 16356646
    Robcio1980
    Rate: 11
    Transit 2.5 td
  • Clarifying Transit engine generation and injection pump type
    #10 16357370
    wojciechjanusz
    Help: 97
    Rate: 465
    Robcio1980 wrote:
    Transit 2.5 td
    Wait, is this a Transit 2.5 TD with Lucas Epic injection system from before 2000? (i.e. either Mk4 or Mk5).
    In the subject of the post you wrote Transit 2.0 ... (i.e. model Mk6).
    In addition, you write that it reacts when firing to the addition of gas - no Transit with electronically controlled injection reacts to gas during firing. Also 2.5TD Lucas Epic. The injection dose during firing is always set by PCM. So I conclude that this is former Lucas Epic, but it has a mechanical Bosch pump with gas controlled gas, the turbine was left. This is a common practice at Epic, because there are very few people in this injection system.
    So what do you finally have?
  • #11 16357972
    Robcio1980
    Rate: 11
    The car belongs to the father-in-law and has always said that it is a Ford Transit 2.0
    Only yesterday confirmed that it is 2.5 TD from 1999 with a Bosch pump
  • #12 16359389
    wojciechjanusz
    Help: 97
    Rate: 465
    Ok, in my opinion it is still aerated, the fuel goes back to the tank. Just a minimal amount is enough and you have to shoot hard.
    The two main reasons are;
    - developed valves of the mechanical feeding pump, during operation the pump still feeds the fuel, but in static conditions the fuel is filtered through it into the tank. These valves are to act as check valves
    - leak in the injection system, on the injector lines, on the injection pump or on the filter mount; if the system was perfectly sealed, even developed valves would not harm, the fuel would be kept under vacuum.
    If I can advise you:
    - buy a fuel pump, a replacement, but not such for PLN 50, only PLN 100-200. (e.g. http://www.ford.ewor.pl/towar/5073/pompa-paliwa-mechaniczna-transit- 1990-2000.html) .; replacement is simple, but with a channel / lift; originally, the pump connectors are fastened with pump connectors, I hope that they are still there, then you remove the cables in five seconds and unscrew the pump in five minutes; the pump is behind the turbine, above the oil pan, driven by a camshaft pusher;
    - change the filter again, clean with a cloth and gasoline the contact surface of the gasket in the mounting base, smear the gasket on the filter with clean oil, fill it with fuel, press it down, tighten.
    - check if there is a leak in the injector overflows,
    - check the pump for dryness, there must not be a drop of fuel under it.
  • #13 20525749
    Robcio1980
    Rate: 11
    Car scrapped
The discussion revolves around a Ford Transit 2.5 TD that has difficulty starting after being turned off, despite having a new battery and a replaced fuel filter. The owner notes that the vehicle sometimes starts after unscrewing the injection pipe, suggesting potential issues with air in the fuel system or the injection system itself. Responses indicate that aeration might be a problem, possibly due to leaks in the injection lines or a failing mechanical fuel pump. Suggestions include checking the injection overflow lines, replacing the fuel pump, and ensuring the system is properly bled to avoid air locks.
