Ford Transit V 2.0 86km 2005: Engine Durability & Defect Assessment for 220,000km Daily Usage
AdrianPec 10983 2
  • #1 16468770
    AdrianPec
    Hello, I want to buy a Ford Transit with a 2.0 86km engine from 5th generation 2005, is this engine durable and is it defective. I would like to add that the car has driven 220,000 and I will be using it in Katowice to transport equipment for the renovation of flats, so about 20-30km a day. I am asking for urgent help.
  • Puma 2.0 TDDI durability and common faults
    #2 16483044
    wojciechjanusz
    Help: 97
    Rate: 465
    This is a Ford design engine, the Puma family, on a traditional Bosch VP30 rotary lobe pump. It has the advantage that the same engines were used on the Mondeo Mk3 until 2006. Then Ford in Mondeo installed PSA engines, and in Transit still Puma engines. This Transit has the designation 2.0 tddi, while the strongest was 2.0 tdci, i.e. common-rail - it had 125KM.
    The 2.0 tddi 85KM engine is considered to be the least emergency among the Puma family, because it is not very powerful and the injection pump has been known for years. If something is wrong in the injection system, then the pump controller (injection angle adjuster transistor) or the pump controller itself.
    The engine has a timing on a chain, 400 kkm will definitely go for replacement, but sometimes the mileage is much higher. This engine version has a simple, single flywheel, so there is no costly replacement of two masses.
    There was an even weaker version of the 75KM, basically the same as the 85KM, except that it had no intercooler.
    Garrett turbine with wastegate valve, which is the simplest solution, basically reliable. Vacuum-controlled EGR, sometimes it cuts - as in all cars.
    In winter, it burns great even after a night in severe frost, with half a turn, but it does not heat up, especially in city driving. On the road, after twenty minutes of driving at a speed of over 100 km / h, he will catch the temperature. In temperatures above zero it is ok, it heats up faster. In Mondeo, electric heaters were installed to heat the fluid in winter or independent of the webasto driver. Not in Transit.
    With a quiet road ride of 90-100 km / h, a small, short Transit 2.0 tddi will burn about 7l with this engine, but in the city you have to count 10 liters. Larger, elevated and extended versions, a bit more.
    If the mileage really is 220kkm, then you still have a lot of driving ahead of you without major problems. Something will always pop up there, because the car is old, but it will be crap.
  • #3 17638711
    naprawa-pomp.com
    Rate: 143
    The vp30 and vp44 pumps have their problems. The main one is a driver and a seized injection angle plunger. In most cases, the car stops suddenly or it cannot be started after a stop. It's really that good symptom and corrupted driver. Worse when the car started to suddenly feel ill, burn more, smoke more, weaken, hard to start. Then the piston from the injection angle adjustment probably seized up. Once, for the regeneration of such pumps, you could hear up to PLN 5,000 in Bosch. The currently available attachments for test tables enabling the control of these electronic pumps have significantly reduced the costs of repairing such a pump and currently the full regeneration of such a pump is about PLN 1,500.
    PUH OMEGA
    brzozowa 57, Ożarów, 27-530 | Tel.: +48XXXXXXXXX (Show) | Company Website: puhomega.pl
