[Solved] Addressing Access Message: Index and Primary Key Cannot Contain NULL Values
marek_kkk 5355 3
  • #1 16310247
    marek_kkk
    Rate: 17
    I have created a simple database with Nr_id, Sex, DataUrodzi, these data are taken from the query to the list on the form. If there is a need to change data, double-click on a given record on the list, which automatically fills in the fields NR_id, Plec, DataUrodzi, and after editing the data in the above-mentioned fields, click on the "Confirm data change" button. Changes are saved. Then I click the "Clear form" button, which clears the fields NR_id, Plec, BirthDate and if the next step is to click "Close form", the message " The index and primary key cannot contain NULL values ". Can someone tell you how to get rid of this message (where did I make a mistake)
    kisses
    • test.rar (78.11 KB) You must be logged in to download this attachment.
  • #2 16313375
    clubs
    Help: 629
    Rate: 406
    Remove the key from NR_id
  • #3 17298157
    marek_kkk
    Rate: 17
    Thanks helped.
  • #4 17298158
    marek_kkk
    Rate: 17
    Thanks helped.
    I deleted the key NR_Id
