- Data in the E-Declarations application
Patfakson 13536 4
  • #1 16370731
    Patfakson
    Rate: 9
    Hello, I fell the system. Due to the fact that I had some important data there, and I do not have another computer, I put the system on the second partition, the system with the system down has been unmoved (I tried to repair some of the methods described in the net, but nothing worked). I have transferred all the necessary data, there is only a question of data from the E-Deklaracje application. Does anyone know how to do it? Where is this data saved? Is it possible to transfer them now?
  • #2 16370755
    Kasek21
    Help: 4981
    Rate: 3547
    Do you want to settle again from a working copy or get an UPO after settlement?
  • #3 16370769
    Patfakson
    Rate: 9
    I have printed the credentials on a regular basis to all members of the household so there is no problem ;) worse with copies of what I sent: p
  • #5 16370806
    Patfakson
    Rate: 9
    Thanks, I'm a finished idiot. I read this topic today. I came to this path ... and instead of reading everything, I copied to the folders: p now improtated the dates file and everything flutters. Thanks for your help and forbearance
