Opel Vectra C 1.8 - Check Engine On, Lambda Sensor & Fuel Dose Adaptation Errors (Bank 1)
faber1234 11352 4
  • #1 16970648
    faber1234
    Rate: 21
    Hello. For a long time I have been burning the chech engine in my Vectra C 1.8. Errors that the computer shows are
    - Lambda sensor circuit - Malfunction (Bank 1 probe 1) fixed
    - Fuel dose adaptation with lambda probe after catalyst too lean (bank 1) fixed
    I am asking for help what to do in this situation, does CHECK smoke from that ??
  • #2 16970686
    asdasss
    Rate: 56
    upload live probe data parameters or check with a meter
  • #3 16970690
    leonov
    Help: 1038
    Rate: 2244
    If there were errors, then what else does the check light up? only from them.
    Check probe bank 1 ;-)
  • #4 16970770
    faber1234
    Rate: 21
    There have long been some errors regarding the probe and fuel dose. But the check was off
  • #5 16971284
    leonov
    Help: 1038
    Rate: 2244
    There are no errors without a check light, unless mechanical errors could be ignored and after a while they went into memory.
