Enabling ADB on Locked Samsung S5 NEO to Remove Google FRP Lock with Z3x
Rekin1970 4833 9
How can I enable ADB on a locked Samsung phone so I can remove the FRP lock with Z3X?
Upload the combination file as AP and flash it; this switches the phone into a software/combination mode with ADB enabled, then you can do the FRP reset [#16314878] After that, do a factory reset, boot to download mode again, and use Reset FRP / React / EE before flashing the normal firmware back [#16315012] If it still asks for the Google account, try an older Z3X version, because version 27.7 was reported buggy while 24.7/24.6 worked [#16317190][#16319670]
  • #1 16314742
    Rekin1970
    Rate: 58
    I got a Samsung to remove the FRP lock, but there is a small problem, ADB must be attached. How to enable them on a locked phone?
    siudziu
    Help: 57
    Rate: 113
    You have to upload the combination file and then you do FRP.
  • #3 16314865
    Rekin1970
    Rate: 58
    I also upload BOOT.
    siudziu
    Help: 57
    Rate: 113
    You upload the combination file as AP, it is one file, you click Flash and you have a software with ADB mode on, then you do FRP.
  • #5 16314978
    Rekin1970
    Rate: 58
    I uploaded the combination file, deleted the FRP and uploaded the G903F_XXUA1OH4_XEG1AOH2 file and unfortunately it still calls the google account password.
    siudziu
    Help: 57
    Rate: 113
    Do so, upload combination File Zrob Reset FRP then factory reset. Then turn on download mode and click Reset FRP / React / EE. Now upload normal soft and it should be ok. You have the G903F model, right? If you have any problems, write to GH or PW.
  • #7 16315102
    Rekin1970
    Rate: 58
    Unfortunately, it did not help.
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    what version of the software you have on your phone
  • #9 16317190
    siudziu
    Help: 57
    Rate: 113
    The problem turned out to be a small bug in version 27.7 on the older version, probably 24.7 went as I wrote.
  • #10 16319670
    Rekin1970
    Rate: 58
    This is exactly how I used the version 24.6 it went from the arrow.
    I close the topic.
To enable ADB on a locked Samsung S5 NEO for removing the Google FRP lock, users need to upload a combination file as AP using software like Z3x. This process involves flashing the combination file, performing a factory reset, and then uploading the normal firmware. Some users reported issues with specific software versions, indicating that version 24.6 was successful while version 27.7 had bugs. If problems persist, users are advised to check their software version and seek further assistance if needed.
