Samsung A510F: Struggling to Remove FRP Google Lock Using Z3X - Seeking Guidance
Rekin1970 5922 6
  • #1 16398226
    Rekin1970
    Rate: 58
    Hello, how the subject came to me such a Samsung to remove FRP but I can not delete it I uploaded the combination file, give Reset FRP like everything is going well and the program shows that it is reset, however, the lock is still there, I tried on different versions of the program and then the same.
    Maybe someone knows how to do Z3X.
    marcin7904
    Help: 138
    Rate: 257
    Upload the modem file from this attachment. After uploading, the phone will turn on, but immediately the screen will appear as if it broke. After that, upload it again soft 1 file and it should go. If after 1 file it won't get up then 4 files.
    • FRP_ Reset_ File_SM-A510FByMasoud.rar (11.9 MB) You must be logged in to download this attachment.
  • #3 16399450
    Rekin1970
    Rate: 58
    I have uploaded the file but nothing happens, the phone comes normally nothing is screaming, one more question in the Combination file are two Combination files and MD5 both we upload.
    tele_sim
    Help: 201
    Rate: 217
    One is uploaded.
    plitom
    Help: 70
    Rate: 35
    What is your android version? For 6, despite uploading the combination file, it showed that it reset frp, but in fact it did not happen, the blockade was still sitting, z3x could not do it, only the way from YouTube gave this using Realterm
    marcin7904
    Help: 138
    Rate: 257
    Try still with this file.
    • userdata.rar (78.72 KB) You must be logged in to download this attachment.
  • #7 16441834
    Rekin1970
    Rate: 58
    It went with realterm. I'm closing the topic.
The discussion revolves around the challenges faced in removing the FRP (Factory Reset Protection) Google lock on a Samsung A510F using the Z3X tool. The user reports that despite uploading a combination file and performing a reset, the lock remains active. Responses suggest uploading specific modem files and using alternative methods, including Realterm, to successfully bypass the lock. The user eventually confirms success with the Realterm method, indicating a resolution to the issue.
