E87 - BMW 116i N43 Engine Fails to Ignite After Spark Plugs Replacement
bombel53 6963 5
  • #1 16316475
    bombel53
    In the BMW 116 and the n43 engine I replaced the spark plugs and then quit smoking. I gave it to a mechanic for a computer that said everything was OK and the timing chain had jumped. I will add that before the candles were changed, the engine burned. Can anyone help me?
  • #2 16316632
    tkaczu1
    Help: 22
    Rate: 92
    Maybe you got the order of the wires from the candles.
  • #3 16316640
    1megan
    Rate: 40
    And what candles are screwed in? NGK ZKBR7A-HTU 91785 or BOSCH 0 242 140 507
    Added after 4 [minutes]:
    There are coils for every candle, there is no way to make a mistake
    Added after 6 [minutes]:
    To replace the spark plug in this engine there must be a special broken key because the channel in which the candle is screwed is bent. With a simple key on a stick, candles can be easily damaged
  • #4 16317905
    bombel53
    NGK candles screwed in with a special key
  • #5 16318002
    sebatrak
    If you turn the engine, you hear a knock? if not then don't schedule it
    first thing you do is check the fuses ...
  • #6 16318895
    bombel53
    Nothing knocks normally turns
    I gave it to a mechanic and he stated ignition coils tomorrow is to put new ones.
