[Solved] BMW E46 Shaking, Weak Acceleration & Gasping - No Spark on Cylinder 4, Clean vs Black Candles
deadredeemer 24216 4
  • #1 17124643
    deadredeemer
    Hi. I have a problem with my e46. Symptoms have such that it shakes the car, gasping interrupts and weakly accelerates. At the beginning I exchanged candles, but nothing was done. As I checked if there is a spark, I noticed that on one pipe there was also a spark between the pipe and the candle. Later I checked how the pipes react without candles when firing. There were sparks on pipes 1-3, 4 of them were not there. 4 candles with previous firing were clean and the remaining ones were black. Should sparks fly from pipes, or are they for replacement, and this could be the reason for this behavior?
  • #2 17124694
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2795
    deadredeemer wrote:
    on one pipe was also a spark between the pipe and the candle.
    With a spark plug placed on the spark plug, they have no right to appear anywhere else than on the gap of the spark plug (in the cylinder). If it is different then either the pipe is burned and needs to be replaced (it may be sufficient to clean) or the candle has a burned side electrode or other problem (central electrode burned, dirty insulator).
    Where did those sparks jump over you and what length?
    Compression is in all cylinders?
  • #3 17125291
    deadredeemer
    Currently after the problem. I exchanged 4 leads and it's ok. Only the cable I took from golf 1.8, and the beta is 318i. Can I leave this guide?
  • #4 17125644
  • #5 17127196
    deadredeemer
    In the near future, it is sure to replace the cables. I did it on Saturday, and the cable was set up experimentally, at least now I know it's cables.
