[Solved] Peugeot 206 1.1 (2005) BSI Replacement, VIN & Immo Pairing, ECU, Eco Mod Mode, 95160 & PP2000
thomas48 32232 11
How do I replace and pair a used BSI with the ECU and immobilizer in a Peugeot 206, and which parts must be virgin or cleaned?
Pair the replacement BSI in Lexia/PP2000 using the BSI replacement procedure, but the BSI must be virgin/clean or new, and the injection calculator (ECU) must also be clean [#16324626][#16325988] Eco mode is just the battery-saving energy mode, and Lexia can exit it [#16324626] The BSI is programmed only once, so a used unit has to be cleared before coding; if the BSI is not a Motce type and uses 95xxx memory, memory translation may be needed [#16324626][#16323563] Key/transponder data are stored in the BSI, with the exact location depending on the BSI software version, and a new key/transponder is added to the immobilizer rather than reusing an unknown used one [#16324196][#16324626] There is no mileage in the ECU, and on Peugeot the mileage can be rewritten by whichever of the BSI or meter contains the higher value [#16324196][#16323563] From PP2000 you can set the BSI to NEW and add a NEW key, but the process does not make a used, already-programmed BSI reusable as-is [#16325988][#16324626]
  • #1 16323557
    thomas48
    Help: 44
    Rate: 83
    Hello all!
    I have been playing with my new Peugeot 206 1.1 from 2005 for a week.
    Bsi 9653667680
    Diagnosis damaged bsi and key switch replaced, no original immo lozenge.
    I replaced the bsi, I changed the vin, I carried out teletransmissions, I changed the immo pin to the original, but still no pairing with the injection calculator.
    questions:
    1. How do you pair the bsi with ecu?
    2. What is eco mod mode? And how to turn it off?
    3. Does the inserted bsi need to be cleared?
    4. Can it be repeated after teletransmission?
    5. Is all the information in bsi written in 95160 or is there another place?
    6. In which memory locations is key information stored?
    7. Can a used remote control from another same car be reassigned?
    8. What is the procedure for replacing the injection calculator and should it be clean?
    Please do not write to have the car serviced by an electrician or buy a starter kit!
    This is my educational peugeot.
    I study at PP2000
    I count on professional help from people familiar with the subject.
  • #2 16323563
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    BSI clean or new.
    A key from this BSI or a new one, otherwise the remote control will not work.
    If BSI is not on Motce and on 95xxx then you could only try to translate memory. In it you have data that interest you.
    In Peugeot, inserting a different BSI or meter, one of these devices rewrites the mileage from the latter which has a larger one. So you have 100 on the counter, you put BSI from a car that had 200 and 200 appears on your counter.
    If the new BSI is 50, it will write 100 from the meter.
  • Questions about key remotes, transponder data, and mileage storage
    #3 16324128
    thomas48
    Help: 44
    Rate: 83
    Bsi used, cleaned (I think good),
    Keys are missing, only new ones remain, I wanted other remote controls (not from this bsi) and I see that they must also be new or so?
    I wrote 95160,
    Ok, I understand the matter of mileage, and ecu also has a saved mileage?
    Does the new transponder save any info when adding to the car? (PCF7936as)
    Thanks for the quick reply.
    I look forward to answering the rest of the questions.
    BSI stores transponder codes, while ECU has no mileage мәғлүм
    #4 16324196
    grala1
    Help: 1495
    Rate: 5052
    There are different types of BSI so I wrote about it so I wouldn't write to others about those on Hank.
    There is no mileage in the ECU.
    As for the key, there are different types.
    From what I see, you don't have a penknife.
    The pocket knife has a transponder soldered on the pilot's board.
    When you give a new transponder at home, you will add it to the immo.
    If you can add a remote control, you would add it now because it is not connected to the transponder.
    In your case, BSI saves the transponder code information.
  • Questions ECU-BSI authorization and transponder pairing behavior
    #5 16324302
    thomas48
    Help: 44
    Rate: 83
    The matter of the type of bsi cleared.
    I have a normal key without a remote control, the pilot will only be looking for how the car will start to drive.
    Then why won't the used transponder be added to the BSI, but a new one, i.e. the transponder also saves something in itself?
    This is another question: ecu receives only information from bsi that there is permission to boot?
    ecu pin and bsi pin must be the same, and bsi paired with ecu, and bsi if it receives a valid transponder signal, does it send permission?
    Returning to the first post
    Question: 1, 2, 3, 4, 6, 8 are still unanswered.
    wolf16
    Help: 32
    Rate: 115
    ad1 Lexia has a BSI replacement procedure
    ad2 economode energy saving mode (not to drain the battery) can be exited using Lexia
    ad3 bsi must be cleaned
    ad4 bsi is programmed once
    ad6 depends on the BSI software version
    ad8 injection calculator must be clean
    klucze.sosnowiec.pl
    Długosza, Sosnowiec, 41-219 | Company Website: https://klucze.sosnowiec.pl
  • #7 16324959
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    thomas48 wrote:
    I study at PP2000
    Do you have any programmer and virgin flaws?
  • #8 16325756
    thomas48
    Help: 44
    Rate: 83
    I meant more, I learn PP2000 and I use it for PSA
    programmers from I2C through SPI, Processor Motki and others.
    Used quite often in various fields of electronics.
    On the way, programmer for 29Fxxx and related memory.
    I ran the batch of ori through the cleaning program, but I'm not sure what made it there.
    I know that he has such a procedure, I meant to highlight the course of the proceedings step by step.
    I have read it or leave it after starting the engine, right?
    And how will it mount other Bsi or will teletransmission take place?
    I am asking for an example and a format of the key recording format.
  • #9 16325988
  • #10 16326396
    thomas48
    Help: 44
    Rate: 83
    georgesgr wrote:
    The rest is electronics / IT at a different level than car repair and investment in "reverse egineering", very expensive in time, equipment and parts. So give it a rest or find a serious subcontractor. I doubt that someone who has invested will share their knowledge here with you ...
    Please read the first post!
    I am going to get this knowledge and the necessary equipment and no matter how long I can afford this car.
    This is the forum to ask questions.
    It is enough for everyone to suggest something + their own experience + exercises.
    Nobody has sucked this knowledge out of mother's milk! everybody got it somehow.
    Please forgive such entries !!!
    Moderated By Pawel wawa:
    I advise you to change the tone significantly. Compare the number of people who were helped alone and who were helped by Colleague George. He is also trying to help you. The demanding style of expression only discourages professionals from helping.
  • #11 16326446
    Help: 1405
    Rate: 6430
    So go for an apprenticeship to a good car electrician, if he wants to accept you, you will learn how to comb 'France'.
    I see no other way.
  • #12 16328267
    thomas48
    Help: 44
    Rate: 83
    I see no other way.
    Thank you for the good advice.
The discussion revolves around the challenges faced in replacing the BSI (Built-in Systems Interface) in a 2005 Peugeot 206 1.1, specifically regarding pairing it with the ECU (Engine Control Unit) and addressing issues related to the immobilizer system. Key points include the necessity of using new keys or transponders for successful pairing, the importance of cleaning the BSI, and the procedure for entering eco mode. Participants emphasize that the BSI must be compatible with the ECU, and that the BSI stores transponder codes. The conversation also touches on the technical aspects of memory locations for key information and the implications of using a used remote control. The use of PP2000 and Lexia diagnostic tools is highlighted for programming and troubleshooting.
