Hyundai Getz: Non-Functioning Turn Signals - Emergency Button Blinking, Fuses Checked
evil454 9015 5
  • #1 16325574
    evil454
    Hello, I have such a problem, namely in Hyundai; the turn signals do not work for me, after switching the lever next to the steering wheel, nothing happens, but if I hold the emergency button, they blink (I will add that I have to hold it to blink, if I press it and let go once they blink and nothing else happens as if there is no sustain). I would like to add that all fuses are in working order (checked with a meter and those in the cabin and those under the hood). Thank you in advance for your help and best regards.
  • #2 16325627
    guciq
    Help: 24
    Rate: 134
    damaged hazard warning light button
  • #3 16325647
    evil454
    If I take it out of the ankle, should the turn signals appear? Or how to check it?
    guciq
    Help: 24
    Rate: 134
    Without it, there will be no turn signals. There are different types of such switches - with such symptoms I exchange for another or a new one and now.
  • #5 16325679
    evil454
    So tomorrow I will check the switch and let me know if it helped
  • #6 16329926
    guciq
    Help: 24
    Rate: 134
    I received "helpful" so I think the problem is solved and the topic needs to be closed
