[Solved] VW Transporter T4 - vw t4 97r 2.5B no turn signals, emergency work and ki
bobas1984 17730 7
  • #1 17167459
    bobas1984
    Hello, I have a problem with the turn signals in VW t4, they disappeared suddenly, the emergency fuses are working, I checked, I replaced the handle and the circuit breaker and then nothing
    andrzej20001
    Help: 1574
    Rate: 6647
    The fuse blows only check with the indicator light
  • #3 17167473
    bobas1984
    I checked the fuses with a conductivity meter approx
    andrzej20001
    Help: 1574
    Rate: 6647
    You can measure it .....
    mati1904
    Help: 5
    Rate: 13
    Most likely a fuse, replace some, you'll be sure. If not, you need to check the power supply and so on with the meter if you have, and not replace it immediately.
    andrzej20001
    Help: 1574
    Rate: 6647
    mati1904 wrote:
    everything in turn with the meter if
    what are you with these meters ?? Zero practice internet theories. We check the high-voltage circuits with a LED
    mati1904
    Help: 5
    Rate: 13
    Well, buddy, it is better to check it with a control in this case to eliminate any voltage drops under load, which the meter will not take into account.
    If anyone knows what he is doing, the meter would also do well ;-)
  • #8 17198545
    bobas1984
    The disadvantages were the hazard light switch, no longer produced by vw, no replacement, the stimulant also came damaged, but a friend of the electromechanical helped to assemble one of the two, it works as long as it turns out
✨ The discussion revolves around a malfunction in the turn signals of a VW Transporter T4 (1997, 2.5B). The user reports that the turn signals stopped working suddenly, despite checking the emergency fuses and replacing the handle and circuit breaker. Responses suggest that the issue may be related to a blown fuse, and recommend checking the power supply with a meter. Some participants debate the effectiveness of using a meter versus a LED for testing high-voltage circuits. The user later mentions difficulties in sourcing a replacement hazard light switch, which is no longer produced by VW, and notes assistance from an electromechanical friend in repairing the existing switch.
