Opel Vectra B - Left Turn Signal Not Working: Indicator Lamp, Relay, Bulb & Emergency Cap Issues
Agent83338 10407 4
  • #1 16985580
    Agent83338
    Rate: 8
    Left turn signal not working. The indicator lamp flashes as if the bulb was burnt and the relay is silent. I have already replaced the relay and the emergency light cap. Bulbs also checked
  • #2 16985769
    bubu1769
    Help: 1177
    Rate: 2374
    It seems that the multitimer is defective, it would be useful to pull it out and review it.
  • #3 16986260
    Agent83338
    Rate: 8
    where should I locate it and how to diagnose it. What is he responsible for?
  • #4 16986288
    bubu1769
    Help: 1177
    Rate: 2374
    Multitimer is responsible for virtually everything related to time in the car, flashers, wipers, cabin lighting. He's in the car's safety box, it's part of it, but after unplugging several relays he goes to pull it out himself. For now, you can pull it out, open its housing and check if there are any obvious defects.
  • #5 16986319
    Agent83338
    Rate: 8
    tell you how to remove it
    oh now the photo showed me
    Added after 49 [minutes]:
    thanks for helping the subject mastered, everything works already
