Stihl MS 180 does not start - the engine does not start when cold, it burns warm
polaris32 16410 5
  • #1 16326547
    polaris32
    Rate: 15
    Hello. I bought the Stihl MS 180 petrol saw. When it is cold, it fires hard, but it is enough to unscrew the candles and fill it with fuel to make it fire. Obviously something with a choke. After such firing, it goes without any problems and burns "kick".
    Can anyone tell you how to fix it?
  • #2 16327084
    guciq
    Help: 24
    Rate: 134
    I submit such topics to the website and usually pay about PLN 30-60. They will take apart, clean and approx.
  • #3 16327283
    lisekey
    Help: 12
    Rate: 77
    Remove the filter and turn the carburetor without it, turn on the choke and see if the throttle closes or the tank is air-tight and no fuel starts. As I wrote in other topics, my MS does not like gasoline under the plug because then it does not go off.
  • #4 16421748
    polaris32
    Rate: 15
    I was in the service, but they noticed a scratch on the cylinder and nothing was done, only the woman who gave it to me told me to give a richer mixture, it will definitely fly a long time.
    It turns out there is not enough fuel on the choke.
    Anyone know how to adjust it?
  • #5 16421852
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    My Husqvarna had similar problems with starting "cold", like problems with choke. It turned out that the seals on the shaft were to blame, they were leaking and the saw had problems with sucking in fuel.
  • #6 16423275
    lisekey
    Help: 12
    Rate: 77
    This carburetor is not tuned, you can only set the idle speed in it, so in the post above, maybe the problem is in a leak and there are such effects on a cold engine.
