Comparing Chainsaws: Stihl MS 180 versus MS 181 - Engine, Construction, and Differences
mickemaster 32472 3
  • #1 16696982
    mickemaster
    Help: 80
    Rate: 166
    I'm preparing to buy a second saw. I have been using MS180 for about 10 years, I repaired it once (piston, sealants, bearings, etc.). It did a lot of work. I would like to ask if buying another one is worth choosing a newer MS181 model. Do MS180 currently available also have a 2 mix engine? Is it worth paying extra PLN to a new construction? What is the main difference between MS180 and MS181?
    best regards
  • #2 16697028
    1 PAWEL
    Help: 674
    Rate: 1364
    MS 181 power 1.5 kW / 2.0HP engine 2-MIX fuel consumption reduced by up to 20%, exhaust gas up to 70%.
    I would stay with the proven MS 180 1.4 kW / 1.9 HP power 2-MIX engine.
    As soon as chain lubrication and maintenance are monitored, it will last a long time.
  • #3 16697035
    mickemaster
    Help: 80
    Rate: 166
    Does it mean that MS181 smokes less by 20% and kopci less by 70% than MS180?
  • #4 16697092
    1 PAWEL
    Help: 674
    Rate: 1364
    MS 181 - Theoretically interesting if it is as much as 70% of exhaust emissions.
    STIHL 2-MIX engine link
    During the flushing process, a fuel-free air layer is placed
    between exhaust fumes and a fresh portion of the mixture in the engine crankcase.
    The result: reduced fuel losses during the flushing process, protection of operator's health and the environment and up to 20% less
    fuel consumption compared to two-stroke models with the same power of 2-MIX technology.
