[Solved] Audi A6 C6 (2005 Model): Persistent High Quiescent Current despite MMI, Navi Amplifier
Pati 17142 3
  • #1 16328542
    Pati
    Help: 35
    Rate: 409
    Hello! For a long time I have been struggling to find out why in c6 2005 there is the phenomenon of "waking up" or not going electronics to standby / rest.
    The car draws rest current at the level of 6-6.5A about a year ago I turned on this car with the same ailment due to the fact that the continuous navi work in the trunk is visible then I got to the side of the trunk I unplugged the device then I fastened everything to myself and after resets in the module settings (due to the fact that I did in several places I do not know which reset was responsible for success) the car "recovered" and the current dropped below 100mA.
    Currently, I have a large part of the modules broken (i.e. MMI, Navi amplifier, comfort module from the trunk and the current has dropped to 0.8-1.2A but the car kind of around with a period of about 1-2 minutes for a while i.e. less than a second turns off the emergency lamp then The lamp from what I see is controlled from the ILM module above the driver's nags and I wonder if this is where to look for a problem, or if another module is responsible for entering sleep mode.
    In general, it looks like something in my eye to wake up all electronics in the car and not let it "sleep" .....
    Best regards and waiting for suggestions
  • #2 16329968
  • #3 16330724
    Pati
    Help: 35
    Rate: 409
    Well, I didn't loop, can such behavior be also caused by the lack of an efficient loop? It may actually loop and check the loop continuity because something had the impression that somewhere there was a loop error ......
  • #4 16330763
