Audi A8 D3 Battery Controller Issues: MMI Display, ABS, Steering Column Errors
McBoss 8577 3
  • #1 16506173
    McBoss
    Rate: 71
    The battery charge status on the MMI is continuously displayed as 0%. The battery controller is changed to the one with the letter "C". Earlier, the state was shown all the time, but the car was drawing electricity and I disconnected the battery every day. Some time ago, after switching on the above-mentioned situation, there were a few other problems (the radio driver, for example, was damaged), I do not know if any overvoltage or short circuit happened from the constant disconnection of the battery ...
    The battery driver spits an error:
    02255 - Voltage Measuring Lead from VBat
    009 - Open or Short to Ground
    In addition, the ABS controller catches an error that returns after being deleted:
    01826 - Sensor for Steering Angle (G85), Supply Voltage Terminal 30
    000 -
    and gateway driver:
    00466 - Control Module for Steering Column Electronic (J527)
    004 - No signal / communication - Intermittent
    The above errors return immediately after being deleted. I replaced the battery with a different one, I adopted it and the problem is still the same. The steering sensor works, the steering column also works, errors on the meter are not displayed. Any advice, gentlemen ??
    Another problem, after connecting the battery and driving a few km, the central locking does not always work. Mostly the car can be closed, but after returning after a few or several minutes, the central one no longer wants to open the car, it only helps to disconnect and connect the battery.
  • #2 16509375
    goldwinger
    Help: 535
    Rate: 2101
    Correct voltage on the test lead (probably thin red)?
  • #3 16509636
    McBoss
    Rate: 71
    And this cable is in the plug for the battery controller ??
  • #4 17605804
    wiechu663
    Rate: 20
    Hello. I have a similar problem with the audi a6c6. For me, the driver from the driver's door and the air-conditioning controller were discharging the battery. After repair, calm for some time. And now he's stealing electricity again and it's just like yours. Did you handle it?
