2013 Toyota Auris - Interior Photochromic Mirror Assembly and Wiring Connection Guide
Emar1313 4485 1
  • Identifying power and ground in five-pin mirror connector
    #1 16331133
    Emar1313
    Hello, honorable forum members.
    I recently purchased a 2013 Toyota Auris. From the beginning, the interior photochromic mirror did not work. After checking, it turned out that the previous owner, wanting to sell the car, replaced the mirror with a photochromatic one and was not connected at all. I have a question about connecting the power to the above-mentioned mirror:
    And this is what the tile in the mirror looks like
    I mean specifically where is the power supply and where is the mass in the 5-pin plug?
  • #2 16437902
    faldo
    Rate: 13
    you have to measure it, you have a diode - there you will find +, and mass on the capacitor. But you'll still need the reverse sensor voltage
