Toyota Auris I 2009 - Best Reversing/Parking Sensors Recommendations: Rear, Front, Sound Only
zajecc 7134 8
  • #1 16812373
    zajecc
    Rate: 9
    Hello everyone, I would like to install the reversing / parking sensors in my Toyota Auris (born in 2009), did any of you buy such sensors and can advise me? I'm not interested in a rear view camera, display etc. just sound and solid product, I personally tracked something like this:
    1. (parking-sensors-reversing-8-sensors-rear-front-i6967227026)
    Toyota Auris I 2009 - Best Reversing/Parking Sensors Recommendations: Rear, Front, Sound Only Toyota Auris I 2009 - Best Reversing/Parking Sensors Recommendations: Rear, Front, Sound Only
    2. (parking-reversing-sensors-front-and-rear-led-extra-i6599154112)
    Please advise what will be the best choice?
    Moderated By CameR:
    Links to Allegro auctions have been removed.
    Reg. 3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
  • #5 16844089
    zajecc
    Rate: 9
    Exactly, I only bought sensors for the back, exactly Link Parking sensors rear VALEO Beep & Park No. 1 632000, but I have a problem after the correct connection according to the instructions, nothing happens, there is no signal, nothing indicates the operation of the sensors. I don't want to drill holes in the bumper before verifying the operation, should there be any signal after shifting, whatever?
  • #6 16844189
    facio7
    Rate: 18
    Check if you have power, it should pop up when you turn on reverse.
  • #7 16845417
    zajecc
    Rate: 9
    Thanks for the hints, the sensors bought and checked, everything works now, only install it permanently and use it, let it work.
  • #8 16845660
    facio7
    Rate: 18
    So there was no power? :D
  • #9 16845858
    zajecc
    Rate: 9
    In Toyota, these wires have strange colors, this is a model made in Japan, not in Turkey, I slowly came to where the weight is, etc. Also there is power and everything works :)
✨ The discussion centers around recommendations for reversing and parking sensors for a 2009 Toyota Auris. Users suggest the Valeo brand, specifically the Valeo Beep & Park No. 1 632000 model for rear sensors. One user experienced issues with the installation, noting a lack of signal after connecting the sensors. Others advised checking for power supply, which was confirmed to be an issue due to unusual wire colors in the Japanese model. After troubleshooting, the user successfully got the sensors to work and planned to install them permanently.
