Improving WiFi Coverage in a Single Family House with Huawei HG8245H Inea 500 Router
Mieciel30 4677 10
How can I get Wi‑Fi coverage on the lower floor of a house when the Huawei HG8245H router only covers the first floor?
The best solution is to run an RJ45/CAT5e cable from the Huawei HG8245H to the lower floor and place a second Wi‑Fi access point/router there; that is better than powerline if you want fast Wi‑Fi [#16331842][#16331862] Powerline adapters were mentioned as an option, but their speed can be mediocre at 500 Mb/s, with one example giving only 35 Mb/s two rooms away [#16331842] A CAT5e twisted-pair cable from a known brand is sufficient for the link [#16331862] For the second device, TP-Link Archer C5 was considered a possible choice, while the Ubiquiti UniFi series was recommended as a very good option and reported to work better than two TP-Link units in one building [#16331936] If the signal only needs to pass one wall and two rooms, coverage should be manageable; interference may matter more than the wall itself [#16331978]
  • Clarifying WiFi coverage needs for the basement floor
    #1 16331823
    Mieciel30
    Hello. I live in single family house. The ISP is inea in the 500mb option. The huawei HG8245H router in gpon technology is added to the service. It is located on the first floor and unfortunately distributes the wifi signal only on this level.
    On the upper floor there are guest rooms and a bathroom. So I don't need internet there.
    My question is as follows:
    What is best to do / buy to have wifi also at the very bottom of the house?
    Thank you very much for every hint
    best regards
  • Use wired access points; powerline speeds vary widely
    #2 16331842
    bogiebog
    Help: 2569
    Rate: 1530
    Additional WIFI points connected to the main router _cable_.
    Ew powerline adapters, but here the speeds can be mediocre at 500mbs.
    For me, powerline adapters (TL-PA4010KIT) slept on 35mbs two rooms.
    As you want fast WIFI, it's only WIFI "ac", 5ghz, devices need to support 5gz ac also.
    Read the alphabet for increasing WIFI coverage
    WIFI antenna - The dependence of the antenna beam angle on the gain
    WIFI propagation in buildings
  • #3 16331852
    Mieciel30
    Yhym.
    And is it possible that, for example, from this main huaweia HG8245H high-class rj45 cable, pull it down and put the router somewhere, I was thinking about tp link archer c5? And of course, configure it somehow?
    Of course they support and about ac technology just thinking about
  • #4 16331862
    bogiebog
    Help: 2569
    Rate: 1530
    Mieciel30 wrote:
    with a high-end rj45 cable pull it down and put the router somewhere, I thought about tp link archer c5?
    very good idea, go to work.
    The CAT 5e twisted-pair cable will be OK, some brand name, e.g. Madex
  • #5 16331868
    Mieciel30
    So I understand that it is doable. Could I contact you in case I can't cope with the configuration?
  • #6 16331922
    bogiebog
    Help: 2569
    Rate: 1530
    Write on the subject, there are many great helpers here to do this setup from one sneeze to the next.
  • #7 16331930
    Mieciel30
    This is just one more little question.
    Tp link archer c5 is a good choice? Do you have any practical knowledge about it?
  • #8 16331936
    bogiebog
    Help: 2569
    Rate: 1530
    the lump
    What budget?
    The Ubiquiti Unifi series is said to be doing very well.
    I had 2 tplinks in the building, they did not give advice, I replaced it with a unifi, it was flying.
  • #9 16331956
    Mieciel30
    PLN 500 I think it should be enough
    Added after 7 [minutes]:
    I will just add that the router will have one wall to cover, 2 rooms next to each other
  • #10 16331978
    bogiebog
    Help: 2569
    Rate: 1530
    I think one wall is OK, more worry about interference than other networks.
  • #11 16331984
    Mieciel30
    Are you talking about neighbors' networks or other disruptions? I do not have any neighbors close to me and I do not find any networks. Unless we're talking about some electronic equipment :)
The discussion revolves around improving WiFi coverage in a single-family house using a Huawei HG8245H router provided by the ISP Inea. The router is located on the first floor, resulting in poor signal distribution to the upper floor. Suggestions include using additional WiFi access points connected via Ethernet cable, considering powerline adapters (though speeds may vary), and potentially replacing the existing router with a TP-Link Archer C5 or a Ubiquiti Unifi series router for better performance. The importance of using CAT 5e twisted-pair cables for connections is emphasized, along with considerations for interference from electronic devices and neighboring networks.
