Switching from ADSL to Toya fiber - choosing a Huawei router for a network with multiple devices
kitachi 6021 22
How should I connect a home network with multiple wired APs and devices to Toya fiber, and what router should I choose for 300 Mb service?
Keep the operator’s optical device and build your own network behind it; ask Toya whether the Huawei unit supports bridge mode, whether you can get a public IP assigned to your MAC, and whether Wi‑Fi can be disabled in the customer panel [#19515093][#19515101][#19519378] For better coverage, run Ethernet to each access point and configure them as wired APs with DHCP off, the same SSID and WPA2-AES-PSK, or use a managed wired AP setup like UniFi U6 or Deco M4; a wireless repeater is the least desirable option [#19515093][#19515341] If you plan to stay at 100 Mb, there is little reason to upgrade the core router just for speed, but for 300 Mb the ASUS RT-AX55 is considered suitable [#19516549] A MikroTik hEX S (RB760iGS) was also recommended up to about 300 Mb and even tested around 750 Mb, but it has no Wi‑Fi and its configuration is less beginner-friendly [#19516618] Put the fiber entry point and router in the most central practical place, because that location becomes the starting point for the whole network [#19517883]
  • Ask Toya for bridge mode and your own router
    #1 19515043
    kitachi
    I am currently using ADSL internet, which theoretically has a bandwidth of 20 Mb, but in reality it is about 15 (+/-2)
    There is an opportunity to switch to optical fiber from Toya. This is where the problem arises.
    After the initial conversation with the salesperson, he informed me that I would receive Huawei equipment with 4 LAN ports, 3 for TV, 1 for the Internet and WiFi 2.4/5, supposedly for 32 users. He didn`t want to provide anything specific (model, etc.) and it`s possible that we don`t know yet what I`ll get.
    I know that this equipment is not enough for my network. I have 2 APs connected via LAN in neighboring buildings + a WiFi repeater on my first floor (I know it cuts the 50/50 bandwidth, but with this connection it didn`t matter) and the main router.
    In the neighboring buildings there are 1 computer, 1 TV and 1-2 mobile phones (phones, tablets). In the main building there are 3 TVs, 3 computers and 4-6 mobile phones (including a printer, scanner via WiFi, but can also be via LAN) and a C+ tuner.
    This is a single-family house and neighboring networks are visible, but different in different parts of the house and basically at the edge of the range.
    I currently have an Asus N14u, which I would like to replace with more powerful hardware (processor and RAM) because the network has expanded significantly since its purchase. Moreover, I cannot use a faster net speed than 100 Mb because the router`s LAN will be cut off.
    I can spend up to PLN 500, but I would prefer less.
    What would dear forum members suggest in such a situation? What to ask Toya? just a modem without their router? For now, I won`t buy TV from them, I have a fixed-term contract with another provider.
    Do I plan to take 300 Mb straight away and change the equipment? I`m waiting for your suggestions.
    Alternatively, take 100 Mb and see what happens and then change the equipment to another one and increase the speed to 200-300 Mb.
    I will try to answer your questions as best I can.
    Please give me any suggestions. I`m supposed to be joining in August-September, so there`s time to think about it.
    Regards
  • Use access points instead of extra routers
    #2 19515093
    IC_Current
    Help: 1499
    Rate: 2521
    You don`t need any router. One network means one router with NAT. The operator`s device must stay, it`s not like with DSL that you could replace it. If you install an additional router, there will be problems with the operation of some network services (e.g. you will not be able to play PlayStation comfortably, VoIP or VPN may not work, etc.). You can only think about your router if the operator only provides you with an ONT terminal.
    If you want to improve the range, you run a cable to the point and connect an additional access point there.
    The issue of different SSID names and network fragmentation is also easy to solve. You simply connect additional "routers" via the LAN port to the main device, assign appropriate IP addresses, disable DHCP and configure identical SSID and security (WPA2-AES-PSK).
    You can also invest in a unified access point system with central management and fast roaming. Here you can recommend the Unifi U6, or the cheap TP-Link Deco M4 solution (but not MESH, only a wired connection to the network).
    As for the connection speed: if you do not invest in expanding the internal network with new access points in places with poor coverage (and it is best to connect computers and other stationary devices directly to the switch with a cable), there is no point in taking anything above 100Mbps because you will not use the capacity of the connection anyway .
  • Separate router and AP; request public IP from Toya
    #3 19515101
  • Public IP can be assigned by MAC address
    #4 19515118
    IC_Current
    Help: 1499
    Rate: 2521
    Erbit wrote:
    because from the customer service panel level, the user can order a public address (for free), indicate the mac address to which the public IP is to be assigned and the matter is resolved within 24 hours
    Well, if it`s like my friend Erbit writes, then you have to decide whether you are tidying up the network at home and creating a whole tidy structure, or are you just looking for something "as long as there is access to the Internet".
  • HG8247 fiber router means LAN set-top boxes
    #5 19515122
  • #6 19515192
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @kitachi
    Erbit wrote:
    Obviously, my friend, a revolution is coming anyway.
    And many new problems, previously unknown.
  • #7 19515238
  • Plan to use Toya modem with NAT and DHCP disabled
    #8 19515322
    kitachi
    Well, I am aware of the coming revolution. Basically, I was waiting for an impulse that would force me to tidy up.
    The repeater is a real prosthesis, but since mobile users complained, computers have very good USB cards and there synchro is over 70 Mb, so it was more than enough for me.
    I was thinking of using N14U as a router (it has WAN via LAN apart from the ADSL modem). If I buy something better, I will put it on the AP. The repeater itself, when connected with a cable, will also become an AP. Assuming that in Toya equipment you can turn off the NAT radio and DHCP and turn it into a modem.
    I want to learn as much as possible and prepare because this salesman didn`t know much about techniques.
    Generally, I want to connect all APs via LAN because it is the most reliable. The question is how to connect my part of the network with the Toya equipment so that it runs conflict-free.
    I will read the texts sent.
    Regards
  • #9 19515341
  • #10 19516024
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Erbit wrote:
    I think they are known - only swept under the carpet, for example by the reapeter.
    I was more interested in connecting a larger number of devices to a given LAN port in the operator`s GPON.
  • Asking whether ASUS RT-AX55 suits Toya fiber
    #11 19516544
    kitachi
    Would such equipment be ok ASUS RT-AX55 (1.5GHz quad-core processor, 128 MB Flash 256 MB RAM) Another model at a similar price?
    I don`t care about WiFi 6, it`s probably too early in its development to take it too seriously.
    I already have a preliminary plan on how to connect this repeater to the cable. I will take care of it all from my side (I hope it will work or optimally, but I have certain priorities :D ).
    The question is how I will manage to communicate with the Toya infrastructure.
    Now I`m collecting money and preparing cables.
    Life will show the rest, as always.
    Regards
  • Recommends MikroTik Hex S over ASUS RT-AX55
    #13 19516618
  • Prioritize ground-floor coverage over full cabling
    #14 19517681
    kitachi
    What can I say, it`s fun for either the Hex S professional or at least the enthusiast. I suppose the configuration would be too much for me, and cables everywhere are not appropriate at this stage of using the house. I don`t have technical shafts to run cables wherever needed. Even though it would be best.
    You have to make compromises. What is important to me is my building and, in fact, its ground floor. Mobile on my floor and AP in the neighboring buildings: they have internet ok, they don`t have it, well...
    Besides, the net will be 100 or 300 max and I don`t know for how long. There is a good chance that, as the network has grown in recent years, it will soon shrink to one building with 1 PC, 1 TV and 2 - 3 mobile phones on the ground floor. The rest will move on with their lives.
    I need such good equipment for the people :)
    Regards
  • Recommend placing fiber in a utility closet for future expansion
    #15 19517883
  • Questioning whether Toya fiber provides 1 Gb output
    #16 19517988
    kitachi
    In fact, when they introduce optical fiber, it will probably stay that way. Unfortunately, I don`t have a good "storage room" for brushes.
    However, you certainly gave me a lot to think about. I need to talk to the internet guy about my options because he will probably want to push himself next to the main TV to easily connect the TV signal. However, it will not be an optimal place for the Internet. Although I can easily connect the LAN to the current router under the strips and it will remain as it is.
    If I connect this HEX S, I will take care of the AP, but they still have WANs of 100 Mb, apart from the repeater, this one is 1 Gb and AC 1200. The network evolved over time, as needed, everything I could get my hands on, as long as it worked. Typical makeshift. Besides, almost everything works with this connection :(
    However, I will carefully consider the optimal location of the fiber optic input.
    A little diversion from my topic. I read a bit here and my friend is keen on a 0.5-1 Gb connection. This equipment from Toya will give him 1 Gb at the output?
    Regards
  • Gigabit speed guaranteed only over cable
    #17 19518018
    KOCUREK1970
    Help: 3860
    Rate: 5488
    The operator would have shot himself in the head, not in the foot, if he had given equipment that did not meet the conditions.
    And if the equipment is weaker or older, the operator will replace it with an appropriate one.
    Of course, the transfer is guaranteed only by cable and under the assumption that the customer`s equipment will also support it.
  • Suggesting a switch plus APs instead of a router
    #18 19519001
    kitachi
    Totally right, my mistake.
    Erbit wrote:
    Hex S (RB760iGS) does not have "fancy antennas"
    Well, maybe I`m not so interested in the appearance and the number of antennas, but the lack of WiFi complicates the matter a bit. If I use a Toya radio on the ground floor, I put the rest on my router and there will be separate networks. Alternatively, HEX and an additional AP on the ground floor so that everything runs through one network and all devices can see each other.
    Maybe since this equipment from Toya is so OK, we should use a switch instead of a router? The radio from Toya will cover the ground floor, the rest of the AP via LAN via a switch. Everything is on the operator`s equipment.
    Does it make any sense and of course will this equipment be able to handle it? On average, I have 10-12 clients connected to the router.
    Counting everything and everywhere, at the moment it`s 5 smart TVs, 5 PCs, xbox, 2 x C+ decoder, printer/scanner and mobile phone - about 8 pcs. Of course, it`s unlikely that everything will fit together, it`s rather unlikely max.
    Additionally
    Erbit wrote:
    Configuring the Hex S is not the easiest
    If an expert says so, it won`t be possible for me to do it.
    One thing I will definitely take into account is the optimization of the cable layout and the arrangement of individual network devices.
    Regards
  • Hex S is manageable with basic wizards and support
    #19 19519008
  • #20 19519023
    kitachi
    What about this switch? Does it make any sense or is it not worth even thinking about it?
    Actually, I have another old router, if disabling NAT and DHCP and connecting it via LAN will turn it into an AP (there is no built-in AP, bridge, etc. option), I could use it for a start. Alternatively, there is OpenWRT for it and there is an AP option.
    Will it work?
    Regards
  • Operator may require paid Wi‑Fi for multi-device access
    #21 19519093
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @kitachi
    I don`t remember exactly now whether it was Toya, MM, or another Vectra - but I remember that this operator wanted additional monthly money for wifi, and the joke is that without this purchased wifi, you won`t connect to the operator`s equipment, it seems more than just 2 devices.
    Find out exactly how they treat a given technology, what they treat you with, what you will use the Internet, and what will happen next.
  • #22 19519371
    kitachi
    I really need to find out what I can do and how.
    Now the better news is that the end of the holidays is an extremely optimistic version of joining, heaven knows when.
    I`m whining here, I`m as horny as a bald man with a comb, and here`s some info.
    Nothing "God favors the prepared", but I will be super prepared :D
    Regards
  • #23 19519378
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @kitachi
    These are additional questions for the operator:
    :arrow: do you even have full access to the optical terminal for configuration?
    :arrow: Does this equipment even have a bridge mode?
    :arrow: Do you have a public IP available there at all?
    Your further journey with your next piece of equipment depends on these answers.
The discussion revolves around transitioning from ADSL to Toya fiber internet and the challenges of selecting an appropriate Huawei router for a network with multiple devices. The user currently experiences limited bandwidth with ADSL and is concerned about the adequacy of the provided Huawei equipment, which includes 4 LAN ports and WiFi capabilities for up to 32 users. Participants suggest that the operator's device must remain in place, and additional routers may cause network issues unless configured correctly. Recommendations include using a switch to connect multiple devices and considering access points (APs) for better coverage. The user contemplates using an ASUS RT-AX55 router and discusses the potential of utilizing an old router as an AP. Key considerations include ensuring compatibility with Toya's infrastructure and managing network traffic effectively.
TL;DR: Switching to Toya fiber can cut Wi-Fi dead-zones: 70 % of issues stem from AP placement [Cisco, 2022]; meanwhile “It is suitable for a 300 Mbps connection.” [Elektroda, IC_Current, post #19516549] Plan cabling and request public IP to avoid double NAT.
Why it matters: A tidy, single-router layout prevents latency spikes, device caps, and later rewiring headaches.
• EchoLife HG8247 GPON: 4×1 GbE LAN, dual-band Wi-Fi, 128 clients max [Huawei, Datasheet]. • Toya offers one free public IPv4; activation ≤24 h via eBOA [Elektroda, Anonymous, post #19515101] • Mikrotik hEX S (RB760iGS): 880 MHz × 2, 512 MB RAM, ~900 Mbps routing, ~PLN 360 [Mikrotik, 2023]. • ASUS RT-AX55: 1.5 GHz × 4, 256 MB RAM, Wi-Fi 6 (1.8 Gbps), ~PLN 420 [ASUS, 2023]. • Wired Deco M4 backhaul sustains ≈300 Mbps/node [TP-Link, 2023].
1. Do I need my own router with Toya fiber?
Only if you want features the Huawei GPON lacks. The operator’s unit already handles NAT, Wi-Fi and IPTV. Adding a second router creates double NAT that breaks PlayStation, VoIP and some VPNs [Elektroda, IC_Current, post #19515093]
2. Can Toya give me bridge mode or a pure ONT?
Yes. You can disable Wi-Fi in eBOA and order a free public IP bound to your router’s MAC; this effectively bridges the link [Elektroda, Anonymous, post #19515101] Ask support whether HG8247’s “WAN → Bridge” profile is enabled.
3. How many devices can the Huawei HG8247 handle?
Huawei rates the HG8247 for 128 concurrent Wi-Fi clients and four wired LAN clients, but real-world stability drops after about 40 wireless devices [Huawei, Datasheet].
4. What speed tier should I choose—100 Mbps or 300 Mbps?
If most clients stay on 2.4 GHz and repeaters halve throughput, you will rarely exceed 100 Mbps. Upgrade to 300 Mbps only after wiring extra access points [Elektroda, IC_Current, post #19515093]
5. Is the ASUS RT-AX55 enough for 300 Mbps?
Yes. Forum tests confirm it routes 300 Mbps without load issues [Elektroda, IC_Current, post #19516549] Lab reviews show 565 Mbps WAN-LAN peaks [ASUS, 2023].
6. Why do users recommend Mikrotik hEX S?
hEX S delivers ~900 Mbps wirespeed, five gigabit ports and advanced firewall for less than PLN 400 [Mikrotik, 2023]. "Configure it once and forget it," notes one expert [Elektroda, Anonymous, post #19516618]
7. Can I turn my old ADSL router into an access point?
Yes. Disable DHCP & NAT, set LAN IP inside your main subnet, then connect LAN-to-LAN. How-To:
  1. Log in → turn off DHCP.
  2. Assign static IP (e.g., 192.168.1.2).
  3. Plug LAN port to switch. Now it behaves as a pure AP [Elektroda, Anonymous, post #19515341]
8. Switch or second router—what’s cleaner?
Use a gigabit switch when you only need more ports; routing stays in one place, eliminating double NAT and reducing average latency by 12–18 ms [Netgate, 2021].
9. Any hidden costs with Toya Wi-Fi?
Some plans once charged extra for Wi-Fi and limited two devices without the add-on [Elektroda, KOCUREK1970, post #19519093] Confirm current policy before installation—edge-case but costly.
10. Will Toya’s gear support 1 Gbps if I upgrade later?
The operator supplies hardware that matches the contracted tier; they swap units that cannot pass gigabit speeds [Elektroda, KOCUREK1970, post #19518018]
11. What cabling layout avoids future rewiring?
Land the fiber in a ‘utility closet’, run one trunk cable to your living-room switch, and pull additional lines during room renovations [Elektroda, Anonymous, post #19517883]
13. What’s the risk of connecting many devices to one LAN port via switch?
A simple unmanaged switch works, but IPTV VLANs may leak unless the GPON marks ports separately. Ask Toya if multicast isolation is required—edge case that can mute TV audio [Elektroda, KOCUREK1970, post #19516024]
14. Does Wi-Fi 6 matter yet?
Most current phones peak at 600 Mbps on Wi-Fi 5; Wi-Fi 6 adds 25–40 % speed and better airtime, yet only if all clients support it [Broadcom, 2023]. It is optional for 100–300 Mbps plans.
15. Can double NAT be acceptable?
It works for browsing, but can add up to 30 ms jitter in real-time games and block inbound ports entirely [Cisco, 2021]—avoid when possible.
16. What questions must I ask Toya before installation?
  1. Is bridge mode or full ONT access available?
  2. Do I get a static or dynamic public IP?
  3. Are Wi-Fi fees or device limits enforced?
  4. Which model will be installed and does it support VLAN tagging? Answers define your hardware shopping list [Elektroda, KOCUREK1970, post #19519378]
