man F2000 - how to set valve clearance in a d26 engine with evb
grzesiek179 20364 4
  • #1 16334409
    grzesiek179
    Rate: 12
    This engine has 12 valves with the additional setting of an exhaust valve. I would like to ask you to describe how to do it and what the clearance values are because when reviewing the subject they are given from 0.5 to 0.8 and for evb 0.35-0.4. I met with 12-valve engines but without evb or 24 valves with evb. thank you in advance.
  • #2 16334477
    darfur5
    Help: 267
    Rate: 1715
    For this engine it's just as you wrote; suction - 0.50, exhaust - 0.80; EVB - 0.35.
  • #3 16334516
    grzesiek179
    Rate: 12
    thanks for this data just just how to adjust it on the exhaust
  • #4 16334575
    darfur5
    Help: 267
    Rate: 1715
    The procedure is similar to 24 valve, you can handle it :D
  • #5 16369062
    grzesiek179
    Rate: 12
    it is set to 0.6 on the main exhaust and 0.35 on evb, you have to remember that the pressure from the chydroposzczenia disappears. if the original valve cover is on it is the diagram and the values of the clearances.
