Beginner Query: Timing Setting & Valve Adjustment Scheme for Mitsubishi L200 2.5, 4D56U Engine Code
max514 37449 4
  • #1 16932100
    max514
    Forgive my colleagues but I am a beginner and I have a question related to the timing setting in Mitsubishi L200 2.5 or maybe some of you have a timing scheme and valve adjustment because I do not want to cut something so I would need a hint of the scheme etc.
    Engine code is 4D56U
    Thank you for the answers if anyone helps
    DriverMSG
    Help: 3984
    Rate: 4883
    You set the valves on a cold engine.
    Suction 0.09mm
    Exhaust 0.14mm
  • #3 16932112
    max514
    Thank Driver MSG
    I just saw some of these signs but I preferred to make sure I was thinking well and I didn't think about YouTube to check :)
    But adjusting the valves is for me a college I need to find something how to do it step by step; (
    Thanks again
    DriverMSG
    Help: 3984
    Rate: 4883
    You need to buy a feeler gauge which will have metal sheets of the above thickness. Next, just screwing the screws.
    https://www.youtube.com/watch?v=dmcwHrW7d2Y
  • #5 16970081
    max514
    Thank you for the hint. Everything plays out, the tips came in handy and are very good
