Opel Meriva 1.7 CDTI Z17DTH Engine: Valve Lash Adjustment, Clearance Settings & Torque Specs
greemlins 14190 4
  • #1 16949498
    greemlins
    Rate: 56
    Hello!
    I am asking for help in finding the correct valve clearance settings in the 1.7 CDTI z17dth engine (opel Meriva), I was looking everywhere and zero specific data. If anyone knows where to get a manual with data on the torque to tighten the screws in the head, please let me know. Thank you in advance for your response.
    robokop
    Help: 1763
    Rate: 6372
    Tolerance 0.35-0.45, all equally.
    mario 77
    Help: 66
    Rate: 335
    Tightening the head:
    1 step - 15 Nm
    2nd step - 39 Nm
    3rd step - 60 degrees
    4th step - 60 degrees
  • #4 16949538
    greemlins
    Rate: 56
    Robokop thanks. Do you know where to find the bolt tightening torque on this motor?
    Added after 47 [seconds]:
    Thanks Mario 77
    Added after 1 [hours] 20 [minutes]:
    I learned that the TIS2000 program should contain all service instructions
  • #5 16955140
    ozon79
    Rate: 29
    Maybe it will help.
    • z17 dth.rar (540.75 KB) You must be logged in to download this attachment.
