Recharging Depleted Lithium Round Batteries with Solar Battery: Feasibility & Methods
mateusz2015_5102 10317 8
  • #1 16335130
    mateusz2015_5102
    Pupil
    Rate: 81
    Hello. I have a little depleted lithium thin round batteries. And can I charge them with solar this solar battery.
    • Recharging Depleted Lithium Round Batteries with Solar Battery: Feasibility & Methods images-5.jpeg (6.52 KB) You must be logged in to download this attachment.
  • #2 16335140
    mariuszp19
    Help: 311
    Rate: 410
    No. They may explode while charging. Organoleptically checked.
  • #3 16335230
    mateusz2015_5102
    Pupil
    Rate: 81
    Cannot charge through solar batteries?
  • #4 16335270
    mariuszp19
    Help: 311
    Rate: 410
    The battery doesn't charge at all. Only batteries can be used.
  • #5 16335946
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4260
    An explosive material is formed in the lithium battery during charging. Designers did a hard job of making a lithium battery that, at least when properly charged, would not produce an explosive reaction. I saw descriptions of two experiments - in one explosion he bent the steel plate and dug shards into the walls (fortunately it happened in the absence of the experimenter); in the second, it damaged an old sink (ceramic) in which the battery was placed (the experimenter took care of a safe cover).
  • #6 16335991
    rafbid
    Help: 153
    Rate: 418
    Probably the charging current was too high and the evolving gases burst the housing. You can't charge because the processes that occur when the battery is discharged are not reversible. Personally, I was able to recharge such batteries at 5-10% capacity and stopped charging.
    A new battery costs PLN 1.5. I don't know a colleague but I assume that a colleague does not have adequate knowledge or measures to perform a safe test. Secondly, there is a risk that the battery will spill over time and damage the device.
  • #7 16336052
    _jta_
    Help: 3212
    Rate: 4260
    And at low current it can explode - electrochemical reactions with lithium take place so that an explosive lithium compound is formed. Do not charge lithium batteries!
    The gas pressure would not cause the steel sheet to bend, it would not shoot debris so that it would stick into the walls - and this was observed when charging the lithium battery.
    Similar problems were with mercury batteries (probably mercury fulminate and the battery exploded), too they were not allowed to load but I don't think they are on sale anymore.
  • #8 16336344
    jarek_lnx
    Help: 4201
    Rate: 6131
    Lithium batteries cannot be recharged, what is worse, as a result of charging, the parameters may deteriorate instead of improve.
    Such batteries often work in clock and memory backup systems, in these systems a diode is used to protect against charging and it can not be any diode, the reverse current of many popular Schottky diodes is too large to guarantee that the total charge "controlled" in the battery will not exceed 1% of capacity.
    Below is an excerpt from the battery application note:
    Renata batteries wrote:
    Inverse Current
    Lithium primary batteries are not rechargeable. Therefore, if there is a possibility of electric current flowing
    from the main power source to the battery, the circuit must include two suitable blocking diodes in series or
    one blocking diode and one protective resistor in series. Use a silicium diode of small inverse current to
    prevent charging. The total amount of re-charge energy due to leakage by the blocking diodes should not
    exceed 1% of the battery's nominal capacity during its total service life. A higher input of re-charge energy
    may harm the battery or reduce its performance.
  • #9 16337562
    mateusz2015_5102
    Pupil
    Rate: 81
    Ok i know I close.
Charging depleted lithium round batteries using solar batteries is highly discouraged due to significant safety risks, including the potential for explosions. Lithium batteries are not designed for recharging, and attempting to do so can lead to the formation of explosive materials and gas pressure buildup. Users have reported that charging these batteries can result in irreversible damage and hazardous reactions. It is recommended to replace depleted lithium batteries rather than attempt to recharge them, as the risks outweigh any potential benefits.
