Building a 12V 50,000mAh Power Bank Using 18650 Cells for Prepping and Solar Charging
348 15
How can I build a 12V 50,000mAh power bank from 18650 cells with solar charging and proper overcharge protection?
You need a proper charge/protection circuit and fusing; the built-in protection on protected 18650 cells is not enough by itself, and the cell spec sheet explicitly calls for appropriate circuitry to protect against short circuits [#21670728][#21670737] Put a blocking diode on the solar input so the panels cannot back-feed at night; one example given was a 1N5401 (3A, 100V), and a Schottky diode or ideal-diode controller is better if you want less voltage drop [#21670730][#21670734] Use a bus arrangement with a fuse for each battery stack or load, make the interconnect wires short and heavy, and size the fuse for about 120% of the intended load [#21670731][#21670735] One reply also warned that lots of cells in series/parallel can deliver very high current, so the protection and wiring need to be designed for the maximum fault current, not just normal use [#21670731][#21670737] For monitoring, a self-powered 20V panel voltmeter with a pushbutton and either a center-zero analog ammeter or separately powered digital ammeter were suggested [#21670730] Several replies also suggested that a car battery or a larger commercial battery pack with built-in protection may be simpler and safer than a large DIY 18650 pack [#21670728][#21670735]
  • Need for a proper BMS and battery configuration
    #1 21670727
    Joel Watson
  • #2 21670728
    Frank Bushnell
  • #3 21670729
    Joel Watson
  • Recommended diode and meter choices for solar charging system
    #4 21670730
    Frank Bushnell
  • Fuse protection needed for high-current battery banks
    #5 21670731
    Chuck Sydlo
  • #6 21670732
    Joel Watson
  • #7 21670733
    Joel Watson
  • #8 21670734
    Steve Lawson
  • Recommend fused bus bar with 120% load fuses
    #9 21670735
    Chuck Sydlo
  • Protection circuit alone is not enough for a 12V pack
    #10 21670736
    Joel Watson
  • Fuse each battery stack to limit fault current
    #11 21670737
    Chuck Sydlo
  • #12 21670738
    Joel Watson
  • #13 21670739
    Chuck Sydlo
  • #14 21670740
    Joel Watson
  • Designing for post-apocalyptic safety and redundancy
    #15 21670741
    Steve Lawson
  • High inverter draw and week-long solar recharge
    #16 21670742
    Tom Dannenberg
The discussion centers on designing a high-capacity 12V power bank using 18650 lithium-ion cells (3.7V nominal) for prepping and solar charging, targeting around 50,000mAh capacity. Key considerations include configuring cells in series and parallel to achieve approximately 14.4V nominal battery voltage and 12V output, integrating solar inputs, and ensuring safe charging and discharging. Protection against overcharging and backflow current from solar panels is essential, typically implemented with diodes (preferably Schottky for lower voltage drop) and dedicated charge controllers or ICs such as the LTC4358. The use of 18650 cells with built-in protection circuits (e.g., Samsung ICR18650) was discussed, but additional external fusing and current limiting are recommended due to high potential currents (up to 83A in combined stacks). Safety concerns highlight the risk of short circuits and the need for fuses or resettable circuit breakers, proper bus wiring with heavy gauge wire, and secure fuse holders. Monitoring voltage and current can be done with low-power panel voltmeters and analog ammeters to avoid battery drain. The design must consider practical load requirements, wiring complexity, and the reliability of components in a post-apocalyptic scenario. Alternative suggestions include using a car battery with a large solar panel for simplicity and longevity. Real-world examples of large battery banks with solar charging and inverter use were shared, emphasizing the importance of sine wave inverters and realistic recharge times.
TL;DR: A 12 V pack built from 18650s can source up to 83.2 A from four parallel 4‑cell stacks—hence the need for fuses, BMS, and solar back‑flow protection; “you could literally weld with them.” [Elektroda, Chuck Sydlo, post #21670731]
Why it matters: This FAQ helps preppers and DIYers safely plan a high‑capacity, solar‑charged 12 V power bank for radios, phones, and laptops.
What’s the safest high-level design for a 12 V, 50 Ah+ 18650 power bank?
Use 4 cells in series to reach 12–16.8 V, then parallel identical 4‑cell stacks. Add per‑stack fusing, a proper battery management system (BMS) for 4S Li‑ion, and a protected DC bus. Include solar input diodes and a main breaker. Plan for high fault current. [Elektroda, Chuck Sydlo, post #21670735]
How do I stop the solar panels from discharging the battery at night?
Insert a series diode on each solar input lead. Choose a diode with reverse voltage above pack voltage and current rating above panel current. Example given: 1N5401 at 3 A, 100 V. Wire with correct polarity and minimize voltage drop. [Elektroda, Frank Bushnell, post #21670730]
Schottky or ideal-diode controller—what’s best for solar backflow protection?
A Schottky diode lowers loss versus a standard diode due to lower forward drop. For higher efficiency, use a MOSFET ideal‑diode controller such as the LTC4358 to further reduce heat and wasted power. “Better yet… LTC4358.” [Elektroda, Steve Lawson, post #21670734]
Do I really need fuses if I’m using lots of small 18650 cells?
Yes. Many series/parallel connections can dump huge current under a fault. Fuse each 4‑cell stack near the bus and size each load fuse at 120% of expected current. This limits damage and allows smaller wiring downstream. [Elektroda, Chuck Sydlo, post #21670735]
How much current can a 4S stack of ICR18650‑26A cells deliver?
The cited max discharge per cell is 5.2 A. A 4‑cell series stack still delivers 5.2 A. Four such stacks in parallel can source about 20.8 A per stack and 83.2 A on the common bus—demanding heavy conductors. [Elektroda, Chuck Sydlo, post #21670737]
Is the 18650’s built‑in protection circuit enough for a big pack?
No. Cell protection helps, but you still need pack‑level safeguards: BMS for 4S balancing, per‑stack fuses, a main breaker, and proper wiring. The shared spec excerpt warns that short circuits create very high currents requiring external protection. [Elektroda, Chuck Sydlo, post #21670737]
What meters should I add for monitoring without draining the pack?
Use a self‑powered 20 V panel voltmeter on a momentary pushbutton to avoid parasitic draw. Use a center‑zero analog ammeter for charge/discharge current; many digital ammeters need an isolated supply. External switching preserves meter batteries. [Elektroda, Frank Bushnell, post #21670730]
What does a protected DC bus look like for multiple loads?
Use a commercial fuse block with a common bus on one side and individual fused outputs on the other. Keep battery‑to‑bus leads short and sized for total current. Rate the bus for the sum of all stacks. This prevents accidental contact and localizes faults. [Elektroda, Chuck Sydlo, post #21670735]
How do I add solar back‑flow protection in three steps?
  1. Select a diode per panel: VRRM above 20 V and current above panel Isc.
  2. Wire each diode in series on the panel positive lead, oriented to pass charge current.
  3. Test at dusk by verifying no reverse current from battery to panel. [Elektroda, Frank Bushnell, post #21670730]
What’s a Schottky diode in simple terms?
It’s a diode with lower forward voltage drop than a standard silicon diode. That means less heat and better efficiency for your solar input or OR‑ing. It’s a practical upgrade over a generic rectifier in low‑voltage systems. [Elektroda, Steve Lawson, post #21670734]
What’s an ideal‑diode controller like LTC4358?
It’s a controller that drives a MOSFET to mimic a diode with very low loss. It prevents reverse current while dropping far less voltage than Schottky solutions, which is valuable in 12 V solar charging paths. [Elektroda, Steve Lawson, post #21670734]
Can I power AC loads like a window A/C from this bank?
Use a sine‑wave inverter. A member reported a 4500 W sine inverter; non‑sine models made the A/C “squeal.” Expect 30–35 A DC draw even at light load and cutoff near 11.2 V. That impacts runtime and recharge planning. [Elektroda, Tom Dannenberg, post #21670742]
How long will solar take to refill a large 12 V bank?
One shared setup used twelve panels at about 1.2 A each (≈14.4 A total) and needed roughly a week to recharge four large batteries. Plan array size for your target daily Wh and acceptable recovery time. [Elektroda, Tom Dannenberg, post #21670742]
What’s an edge case I should design around?
A short on the common bus can unleash welding‑level current from paralleled stacks. Use a main breaker, per‑stack fuses near the cells, and a guarded fuse block. Keep high‑current wiring short and well‑secured. [Elektroda, Chuck Sydlo, post #21670731]
I’m new to this—should I attempt the build?
If you can’t yet implement fusing, BMS, and proper solar protection, pause. The thread shows willingness to help, but safety comes first. Consider commercial Li packs with built‑in breakers and state‑of‑charge indicators to simplify. [Elektroda, Chuck Sydlo, post #21670735]
