Dishwasher - how to connect a dishwasher and a washing machine to one tap and si
Jutysw 55362 8
  • #1 16335646
    Jutysw
    I need help connecting the dishwasher. I already have a washing machine connected to the tap (photo) - is there any option to connect a dishwasher to the same tap (also to cold water of course).
    If I have a siphon with such a tip (photo), can I connect the dishwasher drain? this tip is now built-it must be cut somewhere or is it screwed up?
    Dishwasher - how to connect a dishwasher and a washing machine to one tap and si Dishwasher - how to connect a dishwasher and a washing machine to one tap and si
    please help! :(
    krzysztofh
    Help: 101
    Rate: 937
    Where you have a dishwasher connected (cold water) you need to install the appropriate tee and after the competition.
    With the outflow you can also handle, but the installation of the washing machine and sink drain to the sink siphon is not the happiest idea, because when pouring water from the siphon, it gurgles which is not very nice.
    Each of these devices should be connected to a separate outflow.
  • #3 16335666
    Jutysw
    Unfortunately, this is old enough construction that I do not have the possibility to connect it :( - the washing machine comes out immediately to the sink so the dishwasher and siphon are better connection than the washing machine and the sink ^^
    and this plastic will need to cut a piece or what to do with it?
    This tee is such a thing? http://www.hmpa.pl/?549,trojnik-hydrauliczny-abb-br-3-4-3-4-3-4-
    whether such http://www.hmpa.pl/?521,trojnik-hydrauliczny-bab-br-1-2-1-2-1-2-
    krzysztofh
    Help: 101
    Rate: 937
    The first one to be mounted will be more appropriate.
  • #5 16341745
    Jutysw
    and I can still get information on what to do with this siphon? :(
    Bridgestone
    Help: 30
    Rate: 105
    Measure whether the end of the drain hose fits the diameter of the nozzle at the siphon and if it fits, cut the nozzle at the end, apply the drain hose and tighten with a metal band or cybant.
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    Bridgestone wrote:
    if it matches
    This is what:
    Bridgestone wrote:
    cut the stub at the end
    Bridgestone
    Help: 30
    Rate: 105
    I had in mind the siphon trap, because it will probably be blinded so that the water does not flow.
    zhudomel
    Help: 1280
    Rate: 3373
    Bridgestone wrote:
    he will probably be blinded
    It removes the plug, and does not cut the stub.
The discussion revolves around connecting a dishwasher to the same tap as an existing washing machine. The user seeks advice on using a siphon for the dishwasher's drain and whether modifications are needed for the existing setup. Responses suggest installing a tee fitting to allow both appliances to connect to the cold water supply. Concerns are raised about the drainage setup, with recommendations to avoid connecting both appliances to the same siphon due to potential gurgling issues. The user is advised to measure the drain hose diameter and cut the siphon nozzle if necessary to ensure a proper fit for the dishwasher's drain hose.
