How to connect a washing machine and dishwasher to one wall drain?
Valdi79 17934 4
  • #1 17418273
    Valdi79
    I have a problem with connecting the washing machine and dishwasher to one drain in the wall, but the dishwasher is above the washing machine because it is built-in equipment. I was looking for a double entry washing machine siphon but found nothing. If anyone has an idea how to connect it, please help. greetings
  • #2 17418308
    kindlar
    Help: 919
    Rate: 1622
    Two 90 ° elbows and a tee. https://www.google.pl/search?biw=1280&bih=682...0+tr%C3%B3jnik+90&oq=pcv+30+tr%C3%B3jnik=+90& img.3 ... 91682.95492.0.95752.5.5.0.0.0.0.139.576.0j5.5.0 .... 0 ... 1c.1.64.img..0.0.0 .... 0.Dv4eO0KKIhY # imgdii = GhkLVbDM -Z9ZHM: & imgrc = uHss1ymWQL38hM:
    and https://www.google.pl/search?biw=1280&bih=682...owy+&gs_l=img.3...13768.13768.0.13926.13968.0 .0.0.0.0.0.0..0.0 .... 0 ... 1c..64.img..1.0.0 .... 0.OqyC-4eyvxA
  • #3 17418317
    varga janos
    Help: 22
    Rate: 132
    Hello !
    This may be helpful (?) Styron siphon
  • #5 17418441
    Valdi79
    Unfortunately, I do not have enough space behind the cabinets (80mm) because there is a drain there, but I wonder if something like this would work - only in a simpler version
    https://www.google.pl/search?biw=1097&bih=542...+50&gs.0_l=img.3...119.011.0196.0.0113.119113. 0.0.0.0..0.0 .... 0 ... 1c.1.64.img..0.0.0 .... 0.RYHHyx93JTQ # imgrc = XDu41MyAAU8oIM:
    With a double connection, you can also only plug the lower inlet of the siphon to make it tight?
