Connecting Washing Machine and Dishwasher to One Drain – Splitter Search Assistance
prezesx 54356 10
How can I connect a washing machine and dishwasher to the same drain and water supply using a suitable tee or splitter?
Use a tee on the 50 mm drain line before it goes into the wall, then add a reduction for the appliance drain hose; also make sure the layout prevents a siphon effect between the washing machine and dishwasher [#7047645] For the water inlet, put a 1/2-inch tee before the existing valve and connect the old valve plus the new one from the installation store, or use a double valve in one body instead of ugly reducers and nipples [#7052015][#8214465] Another suggested option was a tee with 45-degree up/down outlets and threaded connections for the appliance hoses [#7053363] The thread also notes that the washing machine and dishwasher have solenoid valves, so water should not “flow back” into the other appliance when one is running [#7051995]
  • #1 7045136
    prezesx
    Rate: 31
    The mice connect the dishwasher to the existing water drain and intake used by the washing machine. I was looking for something like a tee, splitter on the alegro and unfortunately I did not find anything that would suit me :( . Maybe I couldn't name it properly, hence my post on the forum.
    Here I have to connect 2 of the same hose, the one with the blue tip
    Here I have to connect 2 of the same drain hose
    Do you know if there are any suitable branching? as I already mentioned on the allegro, I did not find it. If you have knowledge about such tips that would suit me, please let me know what it is called and possibly a link so that I can see it
    wosokol
    Help: 36
    Rate: 195
    before going to the wall, give yourself a tee (if you have a pipe fi 50) and on one side a reduction for the drain hose. Remember not to get the siphon effect - drawing water from the washing machine through the dishwasher or vice versa. I had such a case once. The client did not know why he pays such water bills! And here the dishwasher drains the water after washing; washing machine disconnected from the socket washing in water; there is no water in the washing machine after a few minutes ;) . the water overflowing from the dishwasher pulled the water out of the washing machine.
    El-tech serwis
    Chełmek Wołowski 25b, Lubin, 59-330 | Tel.: 533XXXXXX (Show)
  • #3 7051958
    prezesx
    Rate: 31
    I think that I will manage to connect an additional drain somehow, worse is the water supply to the washing machine and dishwasher. I think that the siphon effect will not occur because the drain hoses are about 2.5 meters long, a different matter with water supply.
    First: are there any suitable branching to connect the 2 hoses
    leading to one valve. One side must be threaded
    inside and 2 others outside.
    Second: If I manage to connect 2 hoses to one valve
    supplying water whether, for example, turning on a dishwasher, water will not be
    is pulling into the washing machine ??? and vice versa.
    Jasiek690
    Moderator on vacation ...
    Help: 51
    Rate: 158
    Regarding the first one, put the tee, 2 valves and after trouble, or the tee after the valve and the "nipples" with reduction. Regarding the second question, she won't "puff", you have solenoids in your washing machine and dishwasher.
    ANDYW6
    Help: 39
    Rate: 303
    Before the valve you have, give a 1/2 inch tee and connect the current valve and the new one purchased at the installation store to it. Ask for a valve with an outlet to the washing machine, i.e. 3/4 inch. The seller will advise you on what parts to buy. If you don't know plumbing at all, you won't order parts online.
  • #6 7052428
    prezesx
    Rate: 31
    As for the first, put the tee, 2 valves and you're done, or a tee after the valve and "nipples" with reduction . Regarding the second question, she won't "puff", you have solenoids in your washing machine and dishwasher
    The solution with the triplet and nipples suits me best :) Thanks for the help
    andrzej2000
    Help: 43
    Rate: 54
    I had the same problem until I found a 45 degree up and down tee in OBI which I screwed onto the valve and there are threads for water supply to the equipment at the outputs.
    Pzd
  • #8 7054659
    prezesx
    Rate: 31
    [quote] I had the same problem until I found a 45 degree up and down tee in OBI which I screwed onto the valve and there are threads for water connections to the equipment at the outputs [quote]
    I am looking for something like that, unfortunately I did not find it on the Allegro website. It remains to hope that I will get Nomi, Castorama or Leroy Merlin or some specialized shop .. OBI in my village have not yet built :(
  • #9 8213123
    mare37
    Rate: 18
    And I have a similar question: I have a supply valve and a washing machine connected, so now I have to buy a T-piece with a valve instead and connect it to the wall? such a splitter on the washing machine and dishwasher but that the threads fit externally.
    and when it comes to the drain, how to do it so that, for example, water from the dishwasher does not get into the washing machine? I have a sewage pipe in the wall of 50 mm and a drain ball valve attached to it so that odors do not come from the sewage system. Are there any splitters so that the water poured from the dishwasher does not go into the washing machine and at the same time the ball valve (a plastic ball in the middle that closes the drain automatically) blocks it as it does now?
  • #10 8214465
    emdark
    Rate: 12
    I recommend a visit to the nearest supermarket. There are such nice double valves available, i.e. two valves in one body. You can replace the single one from the photos and the power problem solved without ugly nipples and tees.
  • #11 8215457
    mare37
    Rate: 18
    the power supply is not a problem, but it is a drain ... so that the drain does not let water from the washing machine get to the dishwasher hose and vice versa, and that the odors from the sewage system remain.
The discussion revolves around connecting a washing machine and dishwasher to a single drain using appropriate splitters and valves. Users suggest using a tee fitting with a reduction for the drain hose to prevent siphoning issues, which can lead to water being drawn from one appliance to another. Recommendations include installing a tee with two valves or a double valve to manage water supply effectively. Concerns about ensuring that water from the dishwasher does not flow back into the washing machine are addressed, with suggestions for using a ball valve to block reverse flow. Users also mention searching for specific fittings at local hardware stores like OBI, Castorama, and Leroy Merlin, as well as online platforms like Allegro.
