VW Golf IV 1.9 TDI - Clocks and computer hung until completely stopped
atomal 8163 16
How do I fix a VW Golf IV 1.9 TDI instrument cluster and onboard computer that intermittently freeze and then stop working completely?
If the power and ground at the instrument-cluster connectors are good, the fault is most likely inside the cluster itself, and the practical fix is to resolder the PCB or replace the whole cluster [#16336583][#16338203] Check the supplies and grounds with a test lamp of at least 5 W, not just with a meter [#16336583] The symptoms point to a bad cluster board rather than the gauges “exploding” or a loose plug, and one suggestion was to test for the bad area by cooling/spraying or tapping the board while the fault is present [#16338203][#16338775] If you replace the cluster, fitting the same part number lets you transfer the memory and avoid coding in some cases [#16336957] Otherwise, on Golf IV the immobilizer is in the meter, so a replacement cluster may require adding the keys again [#16336916]
  • #1 16336114
    atomal
    Rate: 15
    I have such a problem and I do not know where to look for a solution:
    the clocks (tachometer, speedometer, fuel gauge, temp) along with the on-board computer display gradually stopped, sometimes while driving "hung" on certain indications, then returned and continued to operate live, sometimes worked after the car was started a few minutes and then also everything hung, etc.
    It lasted several months, in different driving conditions, longer and more often, until they came to a complete stand-off, i.e. now, when it is surprising and shows the parameters, it lasts 1-2 seconds and again they hang, 99.9% of the time they hang. The same on-board computer (previously lit on certain indications, also hung - now even it is not lit - nothing displays)
    Interestingly, when the indications suddenly fell so the parameters hang as long as at the time of the last indications - e.g. stand still and there is 70 km / h on the speedometer.
    The only thing that works is the lights, fuel reserves, etc. - besides, the entire dashboard hangs. Similarly, the clock backlight, etc. - always works steadily, the power comes on.
    WHAT SHOULD I DO ? The contacts and wires are working and the spray to improve contacts splashed because I thought that a socket loose behind the clocks was pulled out.
    Golf 4 1999 1.9 TDI 110 HP 5D hatchback with on-board computer
  • #2 16336535
    darekz120
    I have a similar problem with golf IV 1.9 tdi 98r. The car stopped for a while, the battery has discharged, I charged the battery. The dashboard has stopped responding (no indication, only the indicator light from long lights works). In addition, the engine will start and turn off after a second. The turn signals operate. fuses OK. Where to start, maybe some suggestions.
  • #3 16336583
    sk700
    Help: 173
    Rate: 420
    Check the power and weight on the cubes with a light bulb of at least 5W. If they are ok, the counters need to be replaced because there is rather no point in playing CPR.
  • #4 16336753
    atomal
    Rate: 15
    for me, the power supply on the 2 cubes that are next to the dashboard (after removing the clocks) are OK, I checked
    do you think that the easiest way to replace the meters for ~ PLN 100 used with allegro? after replacement, the key needs to be re-coded or is it not necessary?
  • #6 16336957
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    If you buy the same meter number, you will translate the memory and do without coding, etc.
    The second colleague is 99% out of power on the meter.
  • #7 16337820
    atomal
    Rate: 15
    the meter itself is rather efficient, I think something with contacts may be?
    as I wrote - he sometimes works / worked - this is particularly visible on the computer's indications - which calculated cosmic results on residual data, e.g. average fuel consumption 30-32 L / 100 km (and normally it always showed 6-8 L and after using the fuel you can see that it still is)
  • Replace faulty cluster with used unit, swap memory and dials
    #8 16337858
    sk700
    Help: 173
    Rate: 420
    And how do you think the meters are falling? They explode like in American films, destroying windows in the surrounding buildings? :) your damage is clearly in the meter, and no one with the knowledge and tools to repair will take up the subject * because workshops buy these meters from PLN 50. If every penny counts for you, buy the same clocks from an Englishman and replace the memory and dials.
    * does not apply to meters with factory defects which may also appear in a new meter.
  • #9 16337921
    atomal
    Rate: 15
    how familiar with the prices are you how used European golf meters IV 1.9 TDI with full FIS stand?
    because I usually saw the simplest ones for 30-50 zlotys but without FIS, and the computer has now
    with half-FIS they are also 100-150 PLN
  • #10 16338029
    sk700
    Help: 173
    Rate: 420
    atomal wrote:
    but without FIS, and the current one has a computer
    Nowhere have you written that you have a fis. Fis = / = on-board computer.
    If I were you, I would have soldered through the counter plate, replaced the quark. Is there communication with the meter at the moment? Thinking that the car is starting, it should say something, unless it is immo off. If this does not help, then a second counter PLN 200 or English PLN 50-100 and playing with shields.
  • #11 16338084
    atomal
    Rate: 15
    already in the 1st post of the topic, after all, I wrote 3 times that the counters have an on-board computer - both in the description of the problem and the car and I wrote that sometimes it stops (completely extinguishes) and when the computer returns it is based on the remains of the information and has cosmic combustion data, etc. .
    Yes, it has full FIS (I saw some semi-FIS and non-FIS on the Allegro).
    Communication with the meter after the VAG test (laptop + cable to OBD2) IS - the meters start and fall - after the test.
    sk700
    Help: 173
    Rate: 420
    The on-board computer is different from the fis. The car may have a computer and not have a fis, then data such as burning shows on this display where you have the watch.
    How did the mileage behave when the meter was freezing? Was he stopping? If so, after hanging did he count from the state in which he stopped or jumped over the distance driven with a frozen meter? It is very likely that pcb soldering will solve the problem, if you feel confident in smd soldering then do it, if not then give the meter to solder to some electronics because remember that without a meter or with a completely damaged you will not start the car. The surest option will be to replace the meter.
  • #13 16338269
    atomal
    Rate: 15
    oh that's ok :)
    counter and current time (these 2 small simplest small displays as on old watches) work all the time and counting the mileage and hour - similarly the clock backlight / works - when the indications are hanging just stand hands + no display in the middle of the FIS screen / computer between clocks.
    do you need a special microstock soldering iron for such soldering?
  • #14 16338325
    sk700
    Help: 173
    Rate: 420
    No, all you need is a 30W flask and good quality flux, I can't push with a transformer. Unfortunately, the distances between pads are below mm so experience is of great importance. The soldering iron cannot be too powerful either because the pads fall off the plate. It's also difficult for me to point out the specific area on pcb. You have to decide for yourself whether to play it or buy such a counter and change the memory.
  • #16 16338775
    sk700
    Help: 173
    Rate: 420
    Do you have a freezer? If so, connect the car meter and spray the tile piece by piece, it is possible to more or less determine the place. If not, try tapping next places. I certainly would not cling to the megamosa and cana track, before you even solder on the other side you should have uln responsible for analogue indicators. Find their exact symbol, check in the datasheet on which legs they have power and measure them with the meter (of course, in the car with the ignition on and when the meter does not work). Be careful not to short anything.
  • #17 16344052
    darekz120
    The car started, the clocks worked. Thank you all for your help.
The discussion revolves around a VW Golf IV 1.9 TDI experiencing issues with its dashboard instruments and on-board computer, which intermittently freeze or fail to display data. Users suggest checking power and ground connections, and if those are fine, consider replacing the dashboard unit. The importance of matching the meter number for compatibility and the potential need for re-coding keys after replacement is highlighted. Some users recommend soldering repairs on the circuit board as a possible solution, while others discuss the feasibility of replacing the unit with a used one. The conversation concludes with one user successfully restoring functionality to the dashboard after following the advice given.
