Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat
bania2000 6066 6
  • #1 16337944
    bania2000
    The TAB-9800Q tablet at the beginning had a lot of malware that installed itself (from outside the store) and displayed ads, downloaded iRoot and installed the program / programs for cleaning I removed infected files (without this move the tablet was awful and did not react to touch).
    Then the device turned off and you did not want to run only the android logo all the time, after an hour of waiting the black background and the navigation keys turned on and sometimes the lock screen appeared.
    Factory reset does not solve the problem!
    in the bot menu the restoration is yellow code E: fopen error / data / CustomInitLog
    Can I install the pure android here and if it is possible because it is a Chinese tablet so I can not find the original software, or other roms will give the tablet is AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat.
    What can you do? Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat
  • #2 16338040
    nutergsm
    Help: 1034
    Rate: 1665
    Disassemble the tablet and give markings on the disc.
  • #3 16338157
    bania2000
    Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat Malware Issues and Unresponsive Touch on AKAI Makes Sense TAB-9800Q Android 4.4.2 Kitkat
  • #5 16339234
    bania2000
    I can not enter the download mode in the tablet (because all operations are performed in LiveSuit v1.11)
    only the recovery mode opens me.
     The keys on the tablet include volume, power, return and rear reset I tried all combinations
    Can this be done in the usb debug mode? or only the card has been left to me.
    gradek83
    Help: 930
    Rate: 2103
    Did you try PhoenixSuit? Or by phenix Card Tool
    • PhoenixSuit V1.10.00org.zip (16.44 MB) You must be logged in to download this attachment.
    • PhoenixCard_V3.0.6_20110817.zip (1.16 MB) You must be logged in to download this attachment.
  • #7 16339355
    bania2000
    It is thanks to gradek83 that it is beautifully smug :-D
The AKAI Makes Sense TAB-9800Q tablet, running Android 4.4.2 KitKat, is experiencing severe malware issues that led to unresponsiveness and persistent booting problems. The user attempted to remove malware and infected files but encountered a boot loop with an error message during recovery attempts. Factory reset did not resolve the issue, and the user is seeking a way to install a clean version of Android, noting the difficulty in finding original firmware for this Chinese tablet. Suggestions from the forum include disassembling the device for markings, checking firmware from a specific forum, and using tools like PhoenixSuit or Phenix Card Tool for recovery, as the user is unable to access download mode.
