Analysis of Simplified Electric Scheme for Kingway Fonnero 4T Scooter: Engine Starting & Charging
7936 29073 3
  • #1 16340920
    7936
    Help: 15
    Rate: 79
    Please help me to check the correctness of the diagram, the simplest possible version of the electrical installation for the 4t scooter.
    The original diagram comes from the scooter kingway fonnero 4t with a two-wire generator version. I cut out from the diagram everything that seemed unnecessary to me, in order to obtain only the part responsible for starting the engine, charging.
    Why so
    I was looking everywhere where the simplest electric scheme was possible to start the engine without the whole scooter, unfortunately I couldn't manage to understand what is generally available, and I decided to clean the scheme from what was not needed.
    And another question.
    What is a carburetor cutoff? I don't think it will be automatic suction.
  • #2 16344079
    paweld69
    Help: 105
    Rate: 360
    Diagram, missing fuse on +, the rest ok
    You're right, it's sucking. Without a regulator, the suction will get a higher voltage than normal, but that the thermal element should work.
  • #3 16345590
    7936
    Help: 15
    Rate: 79
    Hello. Thank you for your response. I also noticed that the fuse is missing. But this is just a small detail that can be completed in practice. Since the mysterious name (cutting off the carburetor) is the automatic suction module. It is strangely named. The regulator is in the diagram, so he will not get more than the regulator will allow.
  • #4 16348405
    paweld69
    Help: 105
    Rate: 360
    These are translations of importers from the technical Chinese language, so such "language flowers" sometimes appear.
    Yes you are right I did not notice.
