Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection
Candyman11 17892 11
  • #1 16320624
    Candyman11
    Rate: 8
    Hello, I'm new here, and I have a question for you because I can't find on the net, namely:
    I got from a friend of the Chinese cross who stood in his garage for over a year, had a problem with the electrics, there was no wiring harness and module only what was left is a coil and a magneto motor.
    So I bought a new harness, module and ignition switch. I plugged the bundle under the cables that come out of the magneto, module and coil under the ankles that come out of the bundle and unfortunately I don't want to fire. Now my question is whether I connected the cables correctly or do I need to replace something more, and how to connect this ignition switch since there is a cube in the bundle. Pictures attached.
    • Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection IMG_20170303_170606.jpg (2.71 MB) You must be logged in to download this attachment.
    • Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection IMG_20170303_170457.jpg (2.58 MB) You must be logged in to download this attachment.
    • Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection IMG_20170303_160050.jpg (2.8 MB) You must be logged in to download this attachment.
  • #2 16321308
    lisekey
    Help: 12
    Rate: 76
    From what I see, everything is fine, the ignition switch works on the principle that when you short-circuit these two wires cut off the ignition. Check with the meter what voltages come out of the wires, from what I remember green and black and white is the rest by default, maybe it is the fault of the magneto / coil.
  • #3 16321892
    Candyman11
    Rate: 8
    I know it's logical but when checking the cables I have to use kopek what not? because there is no battery
  • #4 16322437
    lisekey
    Help: 12
    Rate: 76
    Yes exactly :D
  • #5 16327455
    Candyman11
    Rate: 8
    I measured the meter and the current is only on white, yellow and black and red and I think that they are from the coil, does it mean that the coil will be inverted?
  • #6 16328055
    Staszek49
    Help: 228
    Rate: 1139
    If the installation is similar to "scooter" ones (from the known country), then the red-black cable is from the high-voltage coil, blue-yellow from the pulse generator and yellow and white, it is light and probably from charging the battery. Compare with the installation diagram, e.g. Router.
  • #7 16328416
    Candyman11
    Rate: 8
    What about this pulse generator cable? Because the power does not come out of it?
  • #8 16329840
    lisekey
    Help: 12
    Rate: 76
    Tomorrow I will check exactly where it comes out because I have a similar engine with two coils and I will give and how.
  • #9 16339979
    Candyman11
    Rate: 8
    Hello again can someone tell me what it is and what is the task? Because the cables are broken
    • Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection IMG_20170216_161815.jpg (3.09 MB) You must be logged in to download this attachment.
    • Chinese Cross 125: Correct Wiring Harness, Module, and Ignition Switch Connection IMG_20170224_135608.jpg (3.23 MB) You must be logged in to download this attachment.
  • #10 16340006
    lisekey
    Help: 12
    Rate: 76
    This is a gear sensor, with or without it will function normally.
  • #11 16340046
    Candyman11
    Rate: 8
    Thanks :) I was afraid that I would have to change something again, I am waiting for a new magneto and no whip, he will have to talk :)
  • #12 16352893
    Candyman11
    Rate: 8
    I don't know what to do anymore, a new magneto, module, harness, coil and still no spark. I measured the cables with the meter and the current is, but it is not on the pulser even though it is new, what should I do?
✨ The discussion revolves around troubleshooting the electrical system of a Chinese Cross 125 motorcycle after the user replaced the wiring harness, module, and ignition switch. The user is experiencing issues with the ignition not firing despite connecting the new components. Responses suggest checking the voltage output from the wires, particularly focusing on the connections from the magneto and coil. The user is advised to compare the wiring with a known installation diagram, such as that of a Router scooter. There are concerns about the functionality of the pulse generator and the overall wiring setup, with suggestions to verify connections and test components for faults. The user expresses frustration after replacing multiple parts without achieving a spark.
