[Solved] Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams
8850 50460 11
How do I troubleshoot and fix a Chinese 50cc 4T scooter with no spark and a hard-to-start ignition system?
Diagnose the no-spark fault by checking the CDI/module, the stator supply coil, the pulse generator, the spark plug, and the high-voltage coil, and disconnect the CDI kill wire to rule out the ignition switch [#17170469] [#17174343] [#17172133] The CDI/AC module usually cannot be properly tested with an ohmmeter because it is potted in resin, so swapping it is often the quickest check [#17170762] Also verify continuity of the wiring and the stator coil outputs; the high-voltage supply coil is around 300 V and the pulse generator can be up to 50 V [#17170469] In this case, disconnecting the black/white kill wire did not restore spark, the pulse generator resistance tested OK, and fitting a new module made the scooter spark and run again [#17172961] [#17190516]
  • #1 17170422
    8850
    Rate: 285
    Hey. I have a Chinese scooter Baotian BT49QT-12 that is 50cm3 and 4T. There is no spark on the scooter on the scooter. It has always been hard to ignite and has not been lighting up lately. What to check in turn?
    Is this an electrical problem on the cables? What colors are going to the ignition (Which cable colors are to be shorted for the ignition switch? Does anyone have an electrical diagram? One thing is certain is the sensor cube of the lowered foot which is bypassed (soldered wires).
    Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams Baotian BT49QT-12 50cc 4T Chinese Scooter: No Spark, Hard Ignition, Troubleshooting Tips & Diagrams
  • #2 17170469
    SKM 1964
    Help: 150
    Rate: 660
    At first glance, I would replace the ignition module, even from a colleague as you have the option. If this does not bring positive results, check the continuity of the wires and the voltage from the stator coils. You can also check their resistances. The coil of the higher voltage supplying the module is about 300V. Pulse generator up to 50V. :|
    What I can see from the eye is the AC module. He does not need battery power.
    How does the coil look like?
    Added after 48 [seconds]:
    Also check the finger (pipe).
    Added after 35 [seconds]:
    Candles too.
  • #3 17170656
    8850
    Rate: 285
    Thank you skm for the answer. I do not have a second module for a replacement and I do not have a friend from whom I could replace. Can I check its resistance parameters on pins with a multimeter?
    I have a second HV coil with an attached pipe because it is welded together and I have replaced one cable - I still have no spark. What kind of tension should it be before the coil and the coil on the pipe? The battery is poor despite charging, I always start from the kopek, not from the starter, although it spins but does not surprise.
    I do not have a second candle - can I check the meter what voltage comes out of the 300V AC pipe when digging? Where to measure the voltage and resistor exactly? Of course, I buy the candle as soon as I check the other options.
    Is the switch accidentally damaged and there is no electrical continuity, it is difficult to get to it by pulling plastics, maybe I can connect some pins to simulate turning the key?
  • #4 17170762
    SKM 1964
    Help: 150
    Rate: 660
    It is enough to disconnect one cable from the so-called quenching and you're already missing it. You can not measure the module yourself with an ohmmeter on the pins and measure it with a multimeter. In them, the thyristors usually sit, but it can be a diode or capacitor and after driving. You can not fix it yourself because it is flooded with resin and not demountable.
    What is the pin layout and what they are connected to you find on the net. It is full of graphics. Enter the AC ignition module and you have. :|
  • #5 17170819
    8850
    Rate: 285
    The probie is that you do not have access to the ignition because of the problem of disassembling the plastics that contain it - someone had previously glued it. Therefore, I would like to disconnect the wires from the ignition switch under the seat or connect them. I do not know if these wires going to the ignition should be shorted at the height of the AC module at the battery or under the seat? How to do it?
    SKM 1964
    Help: 150
    Rate: 660
    Disconnect the 1 wire from the extinguish from the connector on the ignition module and should help if you think it's the fault of the ignition switch, and leave it alone, because you will not get to the order all the more as someone has already fumbled with it. :|
  • #7 17172961
    8850
    Rate: 285
    I disconnected the black and white wire which according to Schemes are used to extinguish, thinking that it is the fault of the ignition and the same thing, the scooter does not start and there is still no spark. So I'm buying a new module, see if it helps.
    SKM 1964
    Help: 150
    Rate: 660
    Such modules were PLN 30 each.
    Did you change candles because I did not read it ?? I saw some people putting their toes in a pipe and checking if they were kicking ?? :D But I advise against such things. :|
  • #9 17174308
    8850
    Rate: 285
    I have not changed the candle yet, I will do it in the near future, I do not intend to put my finger in there because there is a lot of volt there is something I can check and that's it. The module I will buy.
    rafcio_21
    Help: 137
    Rate: 299
    Before you buy a new module, it is worth checking if there is power to this module from the motor and if the pulse generator is functional.
    SKM 1964
    Help: 150
    Rate: 660
    I just mentioned it in the 2 # post but the measurements were not done by the author and he did not check the power supply.
  • #12 17190516
    8850
    Rate: 285
    I measured the resistance of the pulse generator and it is OK. It turned out that after ordering the new module, the scooter started to give a spark and the engine started working, that's why I thank you for the hints, I click helped
The discussion revolves around troubleshooting a Baotian BT49QT-12 50cc 4T scooter that is experiencing ignition issues, specifically a lack of spark and difficulty starting. Users suggest checking the ignition module, continuity of wires, and voltage from the stator coils. The importance of measuring resistance parameters with a multimeter is emphasized, along with the need to verify the functionality of the pulse generator. One user successfully resolved the issue by replacing the ignition module after confirming the resistance of the pulse generator was acceptable. The conversation also touches on bypassing the ignition switch and the challenges of accessing the ignition components due to previous modifications.
TL;DR: No‑spark on a BT49QT‑12? Expect ~300 V AC from the CDI charge coil; "AC module does not need battery power." Check up to 50 V from the pickup, inspect plug/coil, then swap the CDI if readings are good. [Elektroda, SKM 1964, post #17170469]
Why it matters: This FAQ helps Baotian BT49QT‑12 and similar 50cc 4T GY6 owners quickly isolate ignition faults and get spark back.
How do I diagnose no-spark on a Baotian BT49QT-12 50cc 4T?
Use this quick triage:
  1. Measure the CDI charge‑coil output while cranking; you should see around 300 V AC.
  2. Check the pulse generator signal up to about 50 V AC and verify wiring continuity.
  3. Inspect or replace the spark plug, cap, and ignition coil, then try a known‑good AC CDI. This sequence isolates wiring, sensors, and the module efficiently. [Elektroda, SKM 1964, post #17170469]
Does the BT49QT-12 use an AC CDI, and does it need the battery to spark?
Yes. It uses an AC CDI that takes power from the stator while cranking. It does not require battery power for spark. As one expert put it, "He does not need battery power." Confirm stator outputs and ignition parts before suspecting wiring. [Elektroda, SKM 1964, post #17170469]
What color wire is the kill/stop (quench) line, and what does it do?
On this loom, the black/white wire is used for engine “extinguish” (kill). It is tied into the ignition stop circuit. The owner reported disconnecting this line during testing to rule out a bad switch. [Elektroda, 8850, post #17172961]
How do I bypass the ignition switch or kill circuit to test for spark?
Unplug the single kill/“extinguish” wire from the CDI connector. Try for spark again. If spark returns, the switch or stop wiring was grounding the CDI. If nothing changes, continue with stator and module checks. [Elektroda, SKM 1964, post #17172133]
Can I test a CDI module with a multimeter or repair it?
No. You cannot reliably measure a CDI at its pins with an ohmmeter. The unit is resin‑potted and not serviceable. Internal semiconductors fail and cannot be accessed. Replace the module if suspected. "You can not measure the module ... with a multimeter." [Elektroda, SKM 1964, post #17170762]
What voltages should I see from the stator CDI charge coil and the pulse generator?
While kicking or cranking, expect about 300 V AC from the CDI charge coil. The pulse generator produces up to roughly 50 V. Use the multimeter AC range and back‑probe at the module connector. These readings confirm the stator and pickup signals. [Elektroda, SKM 1964, post #17170469]
Should I measure voltage at the spark plug cap or “test with a finger”?
No. Avoid measuring at the plug cap and never touch it during tests. A contributor warned about people putting a toe or finger in the cap and advised against it. Use a spark tester or a grounded plug to check spark. [Elektroda, SKM 1964, post #17173861]
What should I check on the ignition coil, plug cap, and spark plug?
Inspect the ignition coil for cracks and secure terminals. Check the plug cap (“finger/pipe”) for damage or looseness. Replace the spark plug with a known‑good one. These parts are inexpensive and common failure points. Swap a spare coil if available to compare. [Elektroda, SKM 1964, post #17170469]
Should I check the pulse generator resistance before buying a new CDI?
Yes. Confirm the pulse generator’s continuity and that it outputs a signal. Also verify the CDI receives power from the engine. Doing these checks first prevents unnecessary parts purchases. Proceed to a CDI swap only after validation. [Elektroda, rafcio_21, post #17174343]
How much does a replacement CDI module cost for these Chinese scooters?
Expect around 30 PLN for a basic AC CDI module, according to contributor experience. Prices vary by seller and brand. This low cost makes swapping the CDI a practical diagnostic step after measurements. [Elektroda, SKM 1964, post #17173861]
Where can I find the AC CDI module pinout or wiring diagram?
Search for “AC ignition module pinout” and GY6 diagrams online. As noted, “Enter the AC ignition module and you have.” Many graphics show connector layout and wire colors. Match your harness carefully before testing. [Elektroda, SKM 1964, post #17170762]
What finally fixed the no-spark in this thread?
After confirming the pulse generator resistance was okay, replacing the ignition module restored spark. The engine started and ran normally. This supports CDI replacement after verifying stator and pickup signals. [Elektroda, 8850, post #17190516]
