Opel Astra H 1.6 Petrol 2005 - Difficult Morning Starts, Fuel Rail Check Valve & Possible Solutions
Zdunciu89 6567 3
  • #1 16341803
    Zdunciu89
    Hello, I have a problem with starting the car. The worst starts in the morning in 3-4 times, I took out the candles and nothing. In the morning before starting the engine I opened the bonnet and pressed the valve from the injection rail and it gave me the thought that I do not have fuel in the rail and sure is going back to the tank. Maybe someone had such a defect, some reportedly put a check valve.
  • #2 16342058
    piotrekwoj1
    Help: 947
    Rate: 3433
    Zdunciu89 wrote:
    In the morning before starting the engine I opened the bonnet and pressed the valve from the injection rail and it gave me to think that I have no fuel in the rail and probably returns to the tank
    This is not a way to check anything.
    Does the pump turn on when the ignition is switched on?
  • #3 16342334
    Zdunciu89
    Yes, I was on a set of 0 errors, after firing everything Ok, it goes evenly, no choking, no choking on 8h or the next day, then there is a problem with firing
  • #4 16350953
    Zdunciu89
    I put a non-return valve on the pump and it helped the car start in one go, I only need to keep it for 1 sec
    • Opel Astra H 1.6 Petrol 2005 - Difficult Morning Starts, Fuel Rail Check Valve & Possible Solutions 17352736_1270225943055457_1953615078_n.jpg (62.88 KB) You must be logged in to download this attachment.
