Tracking a Stolen Huawei P9 Eva-L09 Phone Even When It's Switched Off
Grackins 17895 9
Can I locate a stolen phone when it is switched off?
No, you cannot track it while it is switched off, and a factory reset also removes most normal tracking options; the police will usually have little chance of finding it [#16344771] The practical step is to report the theft to the police and then go to your operator with the report, contract, and box so they can blacklist the IMEI [#18366448] In one reported case, the operator marked the IMEI as stolen and the phone showed a theft message and the number 112 when it was turned on, even without a SIM card [#18366448] IMEI-based tracing may be possible only in serious cases, and even changing the IMEI does not necessarily make the device untraceable [#16344790]
  • #1 16344737
    Grackins
    Welcome last night from 11-12 March I was stolen from the Huawei P9 Eva-L09 phone. Is it possible to locate it when it is turned off I will add that the battery is built in and can not be removed The worst is that the potential thief could just throw this phone because he was blocked by a pin code, phone code and fingerprint. Gentlemen, you have some advice maybe there is some way to try to locate him on my own hand because the police probably after a month send me a letter about the case and so much the damage to me and the phone which I only had half a year .. Regards
  • #2 16344771
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    You do not track off the switched off, just like you do nothing when someone skillfully restores it to the factory settings.
    The police will not find either, maybe by chance they will succeed, but the chances are poor.
  • #3 16344779
    Grackins
    But if he even resets it to the settings and does a hard reset from the finger, then imei probably stays and if he turns it on with his card, are there any chances?
  • #4 16344781
    Staszek z Chełma
    Level 19  
    Help: 19
    Rate: 56
    The phone, when checking in to the base station gives, among others SIM card number and IMEI number.
    Probably he restored it to the factory settings he put his card and now he is happy.
    You need to look for it after the IMEI number, if it concerns a false alarm, it would have long ago found everyone who had anything to do with this camera (also people who were called or called back and their subsequent calls) regardless of the type and number of SIM cards.
    Alternatively, visit all Lombardy.
  • #5 16344790
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    A colleague above explained everything well, I just add that after imei can be easily traced even if someone changes it because imei does not identify the device.
    However, it must be a serious crime to look that way.
  • #6 16344794
    Grackins
    So there is nothing else to do but wait and count on happiness for the pawnshops I do not know if someone will accept the phone without papers stolen but the suggestion of good
  • #7 16344805
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Grackins wrote:
    if someone will accept the phone without stolen papers
    Engraved on the casing that he stole?
    The commissioner has an appropriate contract and no documents are required when buying a telephone.
  • #8 18366302
    topjar
    Rate: 9
    tino2003 wrote:
    A colleague above has already explained everything well, I will only add that after imei you can easily track even when someone changes it because imei itself does not identify the device.
    However, there must be a serious crime for them to look that way.
    I understand that smartphones or iPhones check in additionally, but is an ordinary Nokia 6300 handset after changing Imei and inserting a foreign Czech prepaid card e.g. to be traced? Sends something else S / N to BTS?
    Such a curiosity
    I accidentally changed Imei samsung to 0 and all BTS in Mazowieckie logged it on without any problem.
  • #9 18366448
    meaverick
    Help: 110
    Rate: 243
    3 years ago I had a case in the Orange network with a stolen phone, I would like to point out that the phone was subscription-based. It was stolen, reported to the Police, I got a copy of the report and with that report, agreement and box I went to the Orange salon. There, after checking my data, the IMEI number of the phone was restricted, the operator reported the phone as stolen, and apparently after logging in even without a sim card, after switching on, a message about the theft of the phone and the number 112 appeared on the display. I will mention that the phone cost PLN 1380. Maybe for this but it is worth going in this direction. Of course, I got the phone back, the reverse unlock procedure lasted 30 minutes and I got my phone back.
  • #10 18366475
    vodiczka
    Help: 1185
    Rate: 4311
    If they had your subscription they had your data and you can report the theft without using the protocol.
    How?
The discussion revolves around the challenges of tracking a stolen Huawei P9 Eva-L09 phone, particularly when it is switched off. Users express skepticism about the feasibility of locating the device after it has been turned off or factory reset. The IMEI number is highlighted as a potential tracking method, but it requires police involvement and is contingent on the phone being turned on with a new SIM card. Some users share personal experiences of recovering stolen phones through police reports and operator cooperation, emphasizing the importance of reporting the theft and the role of the IMEI in tracking. Suggestions include monitoring pawn shops and the possibility of the phone displaying a theft message if it reconnects to a network.
