Quick Video Recovery from Huawei P9 Lite 2017's Memory After Unintentional Deletion
Delphi1999 8538 5
  • #1 17015280
    Delphi1999
    Hello. I just removed an unintentionally very important video from the phone's memory (Huawei p9 lite 2017). I have to recover it quickly. Rotating does not get too much into play because the phone has a month. Greetings.
  • #3 17021195
    Orzel27
    Help: 91
    Rate: 52
    The program from this link damages the software in the phone, most of the comments confirm it.
  • #4 17022508
    blahfff
    Help: 1036
    Rate: 1302
    Generally, without root, there is not even what and how to try. In practice, after that time, the TRIM mechanism did its own and erased the traces. Added to this is forced encryption so real, chances are close to 0.
  • #5 17022844
    Orzel27
    Help: 91
    Rate: 52
    If the data was very important, you could risk losing the warranty. After rotation, the problem disappears if the phone has not been used.
  • #6 17022873
    blahfff
    Help: 1036
    Rate: 1302
    One could, however, the chances of recovering deleted data of this type from the internal memory of the phone in mobile phones, with a working TRIM mechanism, which cleans cells from old, unused data and encryption is virtually impossible. Often even the next day after deletion after the file is only a trace in the form of a name, and after the content even 1o byte does not remain.
    In addition, in this root model you can generally unlock the bootloader, uploading the converted recovery and then the corresponding package. Unlocking the bootloader in turn will restore the factory settings, including clearing and encrypting the internal memory again.
