What 2 in1 station to start with - WEP 898BD vs WEP 898BD + vs ZHAOXIN 898DH
wlaZZ 7536 9
Which 2-in-1 soldering and hot-air station should I buy to start with, and what extra consumables do I need?
A safer choice is to return the unknown BAKU clone and buy the WEP 898BD+, which was recommended as the better option because the soldering iron has 75 W and decent temperature stability [#16351368] For electronics work, also set up the station with ESD in mind and buy flux/flux gel rather than relying only on tin and rosin [#16349061]
  • #1 16347865
    wlaZZ
    Rate: 8
    Which station should I start with? I need a 2 in 1 set. I want a real temperature reading. I will use HotAir to separate screens and later to replace sockets in latops, cells, etc. I do not know what to choose because the seller of 'Hotair' invades Zhaoxins in auctions, while 'Gotronik' criticizes WEPs ... Please give advice. Both were recommended here.
    What in addition do I need to buy? Tin, rosin?
  • #2 16349061
    Gregovic
    Help: 11
    Rate: 21
    Hello, a lot of general information, such as a very wide subject, of course costs, functions when it comes to electrostatic discharge sensitive electronics or the "combine" should be adapted to ESD work, in addition, tin, rosin is rather flux fluxes recommended for such electronics or flux gel, there are actually many described specifics on the electrode ... etc
  • BAKU 702B versus WEP station return decision and temperature accuracy
    #3 16349679
    wlaZZ
    Rate: 8
    I would like to start at 300 PLN. The work that I want to do at the beginning is operations on motherboards from laptops, tablets and mobile phones, e.g. socket replacement. It also needs LCD and housings for separation. Wider application at a later time when I gain knowledge. So far, what the above. I will use the station as an amateur 1 or 2 times a week, maybe.
    Added after 6 [hours] 44 [minutes]:
    Today I bought a BAKU 702B stationary in Poznań, because I thought I would need it quickly, but it turned out that it was not and it is packed. I have 14 days to return.
    Leave this set or it is better to return and buy one of the above. The stock is 22 mm, so WEP nozzles will fit. I guess so too. The only negative thing for me is that there is a compressor in the station, not in the flask. I also do not know if there is a microprocessor or if there is real temperature on the display and on the output. Nothing about this station on the internet. Someone uses and has ??
  • #4 16351368
    Gregovic
    Help: 11
    Rate: 21
    I do not know the company, it is certainly a clone, as I read the tank, I have a power on a 45W soldering iron, I would suggest sending the equipment and buying WEP, but with a plus power on the tip 75W, temperature stability very decent
  • #5 16352484
    wlaZZ
    Rate: 8
    I will also do so ... I prefer certain equipment ...
  • #6 16362396
    wlaZZ
    Rate: 8
    bought WEP 898BD + the topic can be closed ... let me know how it works ...
  • #7 16866926
    Locutus_pl
    Help: 16
    Rate: 15
    Welcome.
    I just have a dilemma which to buy.
    What is your opinion on WEP after 9 months of use?
    Is the blower motor brushless or brushless?
  • Looking for 907F-compatible iron upgrade
    #8 19079639
    s01daT
    Hey, I don't want to create a separate topic, but I also bought an 898bd + and now the question is whether someone tried to replace the stock with something else and does something fit for the 907F? I especially want to change tips faster. As a last resort, I will add a second soldering iron.
    In general, for 3 months, I solder almost every day at night, desolder, heat and it works. There is nothing to fault except for the above-mentioned option of exchanging tips.
  • #9 19086080
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    s01daT wrote:
    There is nothing to complain about except for the above-mentioned option of replacing the tips.
    Tips without a heater belong to prehistory ...
  • #10 19088803
    s01daT
    Only find such a station up to PLN 300 even the soldering station itself.
The discussion revolves around selecting a suitable 2-in-1 soldering station, specifically comparing the WEP 898BD, WEP 898BD+, and ZHAOXIN 898DH models. Users express concerns about real temperature readings and the suitability of these stations for tasks like screen separation and socket replacement in laptops and mobile devices. The WEP models receive positive feedback for their temperature stability and power, with the WEP 898BD+ being favored by some users after personal experience. The ZHAOXIN model is viewed with skepticism, being described as a clone. Additional recommendations include purchasing soldering materials like tin and rosin for effective operation. Users also discuss the need for compatibility with existing tools and the importance of having a reliable blower motor.
