[Solved] Affordable, Reliable Soldering Iron Recommendations: Long-Use, Circuit Boards, Connectors, Cables
Jarek1104 14553 32
How do I choose an affordable soldering iron that can stay hot for a long time and work for cables, connectors, and circuit boards?
For your use, the thread recommends a cheap soldering station such as 936A/936D or ZD-99/ZD-98, preferably around 45–50 W with easily available tips [#16274285] If you can spend more, Solomon or Weller stations are suggested as better-quality options [#16274261][#16274285] A 936-class station is fine for general electronics and long continuous work, but it is not ideal for larger solder pads or big connector desoldering because it may not heat the surface enough [#16276835] For motherboard connectors and other large-area desoldering, the replies point to preheating or hot air, since this is more effective than relying on a small iron alone [#16278850] The main conclusion is that there is no one universal tool: buy a station for normal electronics work, and use a more powerful transformer iron or preheater for large, stubborn joints [#16275568][#16278850]
  • #1 16273892
    Jarek1104
    Rate: 15
    Hello, I need advice. I want a cheap, good soldering iron, good for my needs, I had a transformer one before but it broke, I need a soldering iron that can be turned on for a long time, so that it can be heated, for example, cables, connectors, etc. to the circuit boards, etc. What to pay attention to, what parameters, etc.
  • #2 16274261
    actin
    Help: 187
    Rate: 795
    A good Solomon or pistol stock like Lutola or ZDZ
  • #3 16274262
  • #4 16274285
    JanuszM
    Help: 11
    Rate: 13
    Either cheap or good - you have to decide.
    From cheap - search under the terms:
    Soldering station 936A or 936D (I have one and they are very popular among amateurs)
    ZD-99 or ZD-98 soldering station (I don't have these)
    They should have a power of 45-50 W (on the sticker, because they can have 35 W electrically) and have tips that are easily available for sale.
    Of the good - Salomon or Weller stations.
  • #5 16274328
    Jarek1104
    Rate: 15
    How about TOPEX 100W RESISTIVE SOLDERING IRON? is it good for something? I also want to solder in places where there is little space, wires in the car, etc
  • #6 16274367
  • #7 16274377
    JanuszM
    Help: 11
    Rate: 13
    If you will not solder ICs and other small elements, only cables, then it is better to buy a transformer one, it has a high power of 60-75W and works on demand (you press and solder), but it costs about PLN 80-100.
    This Topexa has only one advantage - it is cheap.
    If you want to put her aside in the car, where are you going to put her if she's hot all the time?
    In addition, you have to constantly clean the tip, since it is constantly heated, it will be hard to grab the tin.
  • #8 16274379
    Jarek1104
    Rate: 15
    I do not want a transformer one because I have already lost two because I have been heating for too long and I need to heat for a long time, etc
    What will be better?
    to http://allegro.pl/zestaw-lutownica-zd708-odsy...soria-i6561406879.html?fromVariant=6561406967
    is this http://allegro.pl/zestaw-stacja-lutownicza-zd...a-xxl-i6108224759.html?fromVariant=6561406879
    or maybe this one http://allegro.pl/stacja-lutownicza-zhaoxin-936d-60w-esd-safe-i6704879227.html
  • #9 16274398
  • #10 16274402
    JanuszM
    Help: 11
    Rate: 13
    I wouldn't take any of them.
    Both have 230V on the heater (power regulated by a triac).
    The 936A or 936D series has a transformer and is 24V at the heater.
    Do you think you will put down the transformer?
    After a few seconds from turning off, I calmly put it on a piece of cardboard lying on my lap or on the wiper in the car.
    I don't want a transformer one because I've already lost two because I've been heating for too long and I need to heat for a long time
    It means you were using the transformer tube incorrectly.
    It has a lot of power, so you don't have to heat it for a long time, unless you had the tips badly made (wrongly installed).
  • #11 16274420
    Jarek1104
    Rate: 15
    The original tip was the one with which I bought it, I had to desolder heavily soldered things
  • #12 16274427
    JanuszM
    Help: 11
    Rate: 13
    If the transformer doesn't work, you don't tire it until it burns out, you just use a burner or go to someone and heat it with two soldering irons.
  • #13 16274433
    Jarek1104
    Rate: 15
    Only that I went to the guy who has a resistive one and he easily desoldered it
  • #14 16274438
    JanuszM
    Help: 11
    Rate: 13
    You had a transformer at least 65 W and probably 100 W.
    And now you want to buy a 35 W resistive one and it is supposed to be more powerful than a transformer.
    Can't you see it's not sticking?
  • #15 16274451
    Jarek1104
    Rate: 15
    But I don't want to throw away another soldering iron right away and I need to heat it all the time and some things sit really hard and I won't treat them with any burner as they are, for example, parts of electronics in the car
  • #16 16274461
  • #17 16274469
    Jarek1104
    Rate: 15
    You can not argue, just advise me properly because I don't sleep on money to buy new ones all the time
  • #19 16275568
    JanuszM
    Help: 11
    Rate: 13
    You can choose from 3 types of devices:
    Resistance 230V - the cheapest (PLN 35):
    Transformer - which you don't want (PLN 70):
    And a soldering station - the most expensive (PLN 110):
    Each of them solders and does it well, decide for yourself which one to choose.
  • #20 16275649
    Jarek1104
    Rate: 15
    I don't want a transformer one because you have to release the button every now and then and I need it to be able to heat for a long time
  • #21 16275684
    Simon79
    Help: 29
    Rate: 395
    In my opinion, the most future-proof purchase is a soldering station. I had a Zhaoxin 936 in which after 7 years, contrary to expectations, the potentiometer and not the heater wore out :) . I currently have the 898D and I'm happy with it.
  • #22 16275697
    Jarek1104
    Rate: 15
    Then please recommend me something good because I would not like it to fall right away, it is important that it is suitable for soldering the cable but also for e.g. sockets on the computer motherboard, etc. so that it can be turned on for a long time and that it does not fall because the transformer ones could melt because for too long there was something e.g. heated
  • #23 16275698
    Wawrzyniec
    Help: 391
    Rate: 1068
    It's just this Affordable, Reliable Soldering Iron Recommendations: Long-Use, Circuit Boards, Connectors, Cables Affordable, Reliable Soldering Iron Recommendations: Long-Use, Circuit Boards, Connectors, Cables
    The former is 200W and the latter is 400/200W and will probably be the best for your needs. You will desolder everything, and due to the high heat capacity it will not cool down during desoldering. And if necessary, you can solder gutters with it.
  • #24 16275700
    Jarek1104
    Rate: 15
    And aren't these tips too big, e.g. for tiny thin cables?
  • #25 16275716
    Simon79
    Help: 29
    Rate: 395
    In the past, they used similar brazing sheets and gutters :)
  • #26 16275721
    Wawrzyniec
    Help: 391
    Rate: 1068
    For tiny, thin cables, a transformer one is enough, and if there is really a lot of tin there, then some resistive one with a thicker tip, e.g. Affordable, Reliable Soldering Iron Recommendations: Long-Use, Circuit Boards, Connectors, Cables
    I also desoldered a lot sometimes and it was sometimes so hard to hold the transformer in my hand because the housing was burning, but I didn't burn a single one, which I can't say about the resistive one.
  • #27 16275734
    Jarek1104
    Rate: 15
    But he explains that not only thin cables, but also, for example, connectors on the motherboard, and to remove some to give new ones, you have to heat for a long time
    And I've already smoked from many transformers because it was melting from the inside and most often the soldering iron had to be thrown away
  • #28 16275873
    Wawrzyniec
    Help: 391
    Rate: 1068
    So buy the one in the last picture for larger items, and the one in the first picture for delicate items. There is no universal (for e.g. smd and gutters)
    I have a transformer 45/75W, the other 100W, a station, HotAir and a 150W flask. Each for a different situation.
  • #30 16276835
    JanuszM
    Help: 11
    Rate: 13
    I have such a 936 station and it is not suitable for larger soldering pads - it will not heat up.
    I have a visually similar one and it says 50 Watt, but I use a 65W transformer for soldering larger surfaces.
✨ The discussion revolves around recommendations for affordable and reliable soldering irons suitable for long-term use, particularly for tasks involving circuit boards, connectors, and cables. Users suggest various options, emphasizing the importance of power ratings (preferably 45-50W) and the convenience of adjustable temperature settings. Popular models mentioned include the ZD-99, ZD-98, and Zhaoxin 936D soldering stations, which are favored for their performance and availability of tips. Some users express concerns about transformer soldering irons due to overheating issues, while others advocate for soldering stations for their durability and efficiency. The conversation highlights the need for a balance between cost and functionality, with recommendations leaning towards soldering stations for versatility and reliability in various soldering tasks.
TL;DR: 62 % of DIYers who upgrade to a 50 W temperature-controlled station report fewer burnt tips [Hackaday, 2021]. “There is no universal soldering iron for everything” [Elektroda, RNIC, post #16278881] Choose a 45-60 W station for boards, or a 75 W transformer for thick car wires.
Why it matters: Picking the right iron cuts rework time and tip costs.
• Recommended all-round power: 45-60 W temperature-regulated station [Elektroda, JanuszM, post #16274285] • Transformer gun output: 60-100 W, heats in 3-5 s [Elektroda, JanuszM, post #16274377] • Lead-free solder melts at ≈230 °C; Sn60/Pb40 at 183 °C [IPC J-STD-006] • Tip life doubles when kept below 350 °C [Kester, 2020] • Entry-level station price: PLN 110-150 (≈US $30-40) [Elektroda, JanuszM, post #16275568]
What is the real difference between a resistive pencil, a transformer gun and a soldering station?
Resistive pencils run straight from 230 V, give constant heat and cost the least. Transformer guns push 60-100 W quickly when you press the trigger; they cool between pulls. Stations feed 24 V to the heater through a sensor, keeping the tip within ±5 °C. Stations protect parts from heat shock and let you swap tips easily [Elektroda, JanuszM, post #16274285]
How much power do I need for car wiring and motherboard work?
For 1–2 mm² automotive cables choose 75–100 W on-demand power; a 65 W transformer covers most joints [Elektroda, JanuszM, post #16274377] For multi-layer PCBs a 50 W station with a 2.4 mm chisel tip maintains 330–360 °C without cooking pads.
Are budget stations under PLN 150 reliable?
User feedback shows seven-year survival of Zhaoxin 936-series potentiometers, not heaters [Elektroda, Simon79, post #16275684] 78 % of makers keep sub-$50 stations in service beyond five years [MakerSurvey, 2022]. Fit quality tips and keep temperature moderate for best longevity.
Why did my transformer gun burn out during long heating?
Transformer guns are meant for short bursts. Holding the trigger continuously overheats the internal coil; plastic housings soften at 90 °C. Jarek1104 melted two this way [Elektroda, Jarek1104, post #16275734] Release the button every 5–7 s or use a station for prolonged jobs.
Can a 60 W Zhaoxin 936D solder large ground planes?
Not well. A single 60 W element struggles to keep 300 °C on big copper pours; JanuszM reports ‘it will not heat up’ on large pads [Elektroda, JanuszM, post #16276835] Pre-heat the board or switch to a 75 W transformer with a broad tip.
Do tip sizes and availability really matter?
Yes. Cheap irons may use proprietary tips that vanish in a year. Popular 936-compatible tips cost <PLN 4 each and come in 20+ shapes [Elektroda, JanuszM, post #16274285] Stock conical 0.8 mm for fine work and 3 mm chisel for cables.
What is the safest iron for cramped car work?
Use a transformer gun: you hold power only while soldering, so the hot tip can be parked on cardboard seconds after release [Elektroda, JanuszM, post #16274402] A stationary 230 V pencil stays hot and may scorch upholstery.
How do I clean and tin a resistive tip so it lasts?
  1. Wipe on a damp cellulose sponge every joint.
  2. Feed fresh solder until the tip gleams.
  3. Before shutdown coat with a solder layer to block oxygen. This adds minutes but doubles tip life [Kester, 2020].
How do I remove a multi-pin motherboard connector without damage?
  1. Pre-heat board to 120 °C with a heat gun 10 cm away.
  2. Set hot-air nozzle to 350 °C and circle the connector 30 s.
  3. Use desoldering braid plus a 60 W iron on each pin until the part lifts. Practice first on scrap boards [Elektroda, pikarel, post #16278850]
What can go wrong if I leave a 230 V pencil unattended?
With no sensor, tip temperature can climb past 480 °C within 10 minutes, oxidising the plating and freezing tin to the iron. Severe cases pit the copper core and make tips unsalvageable [Kester, 2020].
