Best Soldering Station for Amateur Use: Audio Cables, Phone & Computer Repair (Budget 150-200 PLN)
Dezmos 7218 9
Which soldering station should I buy for amateur use to solder audio cables and occasionally repair phones or computers on a budget of 150-200 PLN?
For this budget, the Bakon 950D 75W ESD is a strong choice, and a T12-based station is an even better option if you can get one cheaply. The Bakon 950D is praised for having the real 75W power, fast heating, accurate temperature measurement, and a heater built into the tip, plus a large selection of tips; the advice is to choose the right tip for the job [#16605973] T12 stations are recommended because they warm up much faster than traditional stations, and the tips are reasonably priced on AliExpress [#16615060][#16616996] If you want a more conventional station, the WEP 936A in the 75W version is also recommended for electronics repair [#16605246]
  • #1 16604072
    Dezmos
    Hello, I would like to buy a soldering station for full amateur use. It would be used to solder smaller cables (e.g. audio) and from time to time when repairing phones or computers.
    I would like to spend max. PLN 150-200
  • #3 16605246
    ZimnyDrops
    I recommend the WEP 936A + 75W station, it is important that this was the 75w option. I'm using it to repair electronics. It is only important to choose the right tip.
    best regards
  • #4 16605797
    Lomax33
    Help: 13
    Rate: 26
    I use Yihua 853DA and I'm happy too. The cost is about 300 PLN but it is 5 in one ... you have an additional 15V workshop power supply, RF tester and an ammeter
    tomiok
    Help: 133
    Rate: 292
    Up to PLN 200 - Bakon 950D 75W ESD soldering station.
    And there are no strong ones, strong and it's easy to take with you a large selection of tips, including a "BGA spatula", and a mini wave.
    The actual power of 75W, not like some give a kind of instantaneous, because I could write over 100W, and it heats up quickly.
    But more importantly the temperature measurement is in the cave, so it has an accurate measurement.
    It also has a heater built into the arrowhead, which causes it to heat up very quickly, and if the heater breaks, we change the tip itself and after trouble.
    I know what I am writing about because I have several different ones, but I often reach for it.
    As for those like 75W in a soldering iron for REPRO, WEP, Yihua 907F 936A 937D + 898D + 872D + stations
    This is 50W and that's how much the 907f flask has.
    To illustrate what I am writing about the store screenshot:
  • #6 16606566
    Ferdynand Kiepski 01
    I recommend Zhaoxin 936dh
  • #7 16615010
    Dezmos
    Thank you for your help, and now I'm thinking about WEP 936A + 75W and Bakon 950D 75W ESD and I think I'm tempted to use Bakon 950D 75W ESD because it is more mobile.
  • #8 16615060
    elektryku5
    Help: 460
    Rate: 1055
    I do not have a 950D, but I can recommend T12 stations, the warm-up time is an abyss to traditional stations, and at ali the caves have quite reasonable prices (I am also tempted to try the original tip).
  • #9 16616996
    tomiok
    Help: 133
    Rate: 292
    Dezmos wrote:
    ... and I think I'm tempted to Bakon 950D 75W ESD because it's more mobile.
    In my opinion, there is nothing to wonder about.
    Bet on the T12 grottoes - you won't regret it.
  • #10 16617146
    Dezmos
    Bakon 950D ordered thank you for your help, I close it and hope it will work well :)
The discussion revolves around selecting a soldering station suitable for amateur use, particularly for tasks like soldering audio cables and repairing phones and computers, with a budget of 150-200 PLN. Recommendations include the WEP 936A + 75W, noted for its reliability and the importance of choosing the right tip, and the Bakon 950D 75W ESD, praised for its portability and accurate temperature measurement. Other suggestions include the Yihua 853DA, which offers multiple functionalities but exceeds the budget, and the Zhaoxin 936dh. The Bakon 950D was ultimately chosen by the original poster for its mobility and features.
