- Determining Accurate Current (Amperage) for Phone Charger: 1A vs 2A Comparison
grsmagik 18675 14
  • #1 16358602
    grsmagik
    Hello, how do you decide what current (how much Amper) the phone charges my charger ??
    I want to know if I got a sell that loads 1A and it's written 2A because the charger loads very poorly.
    Greetings.
  • #2 16358610
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    The charging current is managed by the phone and not by the charger.
  • #3 16358622
    mariuszp19
    Help: 310
    Rate: 408
    Yes, but only up to the maximum value of the charger's current. If this can not be done, management will not do anything.
  • #4 16358626
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    The phone manufacturer probably knows best what kind of current a charged battery should be and attaches to the appropriate power charger.
    If you want to measure the current supplied by the charger, connect the ammeter in series with the power output.
  • #5 16358630
    mariuszp19
    Help: 310
    Rate: 408
    That's right, only the author of the threads did not write whether it's the original charger attached to the phone.
  • #6 16358645
    grsmagik
    I am green, I have a multimeter how to connect it in series to the charger?
  • #7 16358655
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    Write what phone it is.
  • #11 16358741
    grsmagik
    leonov wrote:
    Install the program from the store :D otherwise you will not face, but how reliable it will be :?:
    The program shows that I do not have a sensor and the measurement may be inaccurate.
  • #13 16358780
    Piotrek#G
    Help: 83
    Rate: 300
    link
    Buy yourself such a clutch. It costs a dozen or so zlotys and is very useful.
    nutergsm wrote:
    If you do not measure it is enough to use an appropriate tester / meter for usb, e.g. such http://www.gotronik.pl/miernik-napiecia-pradu-mocy-portu-usb-p-3994.html
    Only sometimes not for the price ...
  • #14 16358856
    grsmagik
    Piotrek#G wrote:
    link
    Ok, I'll think about it. I still have a question about the charging cable. Which cables do you recommend 2.1A for fast and accurate charging?
    I want to buy it, because these 1A Chinese cables are driving me crazy.
  • #15 16362096
    rogos87
    Help: 5
    I recommend "Chinese" or BlitzWolf cables, very nice are bilateral bilateral, you can connect as you like, although they are a little expensive and probably not available in Poland. http://www.blitzwolf.com/BlitzWolf-BW-CB6-2.1...o-USB-6.56ft2m-Charging-Data-Cable-p-103.html I have two such 2m, they are very good quality, tablet charged with a current of about 2A.
✨ The discussion centers on determining the appropriate charging current (amperage) for phone chargers, specifically comparing 1A and 2A outputs. It is clarified that the charging current is primarily managed by the phone, which draws current up to the maximum capacity of the charger. Users are advised to measure the current using an ammeter connected in series with the charger. The conversation also touches on the importance of using quality charging cables, with recommendations for 2.1A cables for faster charging. Brands like BlitzWolf are mentioned for their reliable products.
