USB Car Charger 3x 2.4A - Long 5m MicroUSB Cable Issue: Does Length Affect Charging?
zbyszek100 9648 10
Why does my phone only maintain battery level on a 5 m microUSB cable from a USB car charger instead of charging normally?
Yes — a 5 m microUSB cable can cause too much voltage drop, so the phone may only hold its charge instead of drawing full current; in this thread the cable length and/or thin, poor-quality conductors are identified as the likely cause, not the car charger itself [#16625720] [#16625727] [#16625783] Use a shorter cable with thicker power wires, ideally a two-wire power-only cable with low AWG, because cables with data wires often lose too much voltage under load [#16625783] If you buy a ready-made cable, its outer thickness is only a hint; even “copper” cables can be bad, so a cheap cable may still be unsuitable [#16625727] [#16625783] One practical workaround is to move the power source closer by installing an extra cigarette-lighter socket nearer the phone [#16627151]
  • #1 16625694
    zbyszek100
    Rate: 207
    Hello, I have a car charger, 3x USB 2.4A. I attach a 5m microusb cable to it, wanting to charge the smartphone. On this cable, unfortunately, the phone is not charging, it only maintains a given% battery charge, the battery charging app shows 270mA on this cable. On the shorter and original cable that I plug into the car charger it loads normally, the app shows 1710mA. Now the question is whether the length of the microusb cable matters, hence it does not charge, but only supports, because it is up to 5m? Did I just buy low-quality junk and if I add a few zlotys more, will it charge even this length of cable? I have such a long cable because I hid it in plastic so that it could not be seen, it comes out next to the handle. Thanks for the help.
  • #2 16625720
    gracjan55
    Level 36  
    Help: 315
    Rate: 244
    USB cable too long.
  • #3 16625722
    zbyszek100
    Rate: 207
    How much length can I afford to load? (I am pissed by hanging cables in the car)
  • #4 16625727
    piwko
    Help: 87
    Rate: 214
    gracjan55 wrote:
    USB cable too long.
    Or a crap cable, made of steel instead of copper. Check with a magnet.
  • #5 16625736
    zbyszek100
    Rate: 207
    The correction is a 3m cable. Now I saw it at the auction. The description is like:
    Material: PC, Copper, Nylon
    I paid 8 zlotys for it with delivery ;)
  • #6 16625743
    piwko
    Help: 87
    Rate: 214
    Tia, copper. Put the magnet on, you may be surprised. I had it too, the cable looked like ori samsung.
  • #7 16625765
    zbyszek100
    Rate: 207
    I will do it tomorrow and report. I hope he gets caught through nylon, he doesn't want to blow it.
    So far I'm ordering a new cable, do you think Esperanzie, Platinet can be trusted? This time I will buy 2 sq m.
  • #8 16625783
    Ture11
    Help: 573
    Rate: 1130
    Colleagues, what's the difference, what the cable is made of - if even copper can have a small diameter.
    I will tell my friends honestly that I have dealt with testing the cables and microUSB power supplies for the purpose of powering the Raspberry Pi 3 (current consumption max. 2.5 A, low voltage alarm at 4.75 V). All USB-microUSB cables can be removed, they share the space of the power wires with the data wires., Most power supplies of various production could not cope with RPI power supply due to too thin wires in the cable - to the extent that one of the power supplies gave a voltage of 5, 4 V just to have a "spare" - it was constructed this way, but it is a digression. Of course, I conducted voltage drop tests on load and ammeter + voltmeter.
    Any connection of the power supply with a USB cable (with data wires) ended in a significant voltage drop on the cable. We're talking about max 1.8m cables, and a colleague tries with a 3-meter Oo
    The only two solutions that worked well with Raspberry - is a Polish power supply, some random Extreme with an integrated cable (I cut it - there were two, beautiful, copper) and a K&M plug-in power supply with detachable microUSB cables (cable without USB communication function, only for power supply).
    Buddy, my friend has a difficult matter. Providing any company as a good one will not do anything - because maybe it just invested in ferrite filters, a thicker insulator or even shielding - and it could let off the diameter of the power wires.
    If your colleague is able to solder - I would recommend here - buy the plugs: USB, microUSB and the right amount of solid two-wire cable with the least AWG (and good flexibility).
    If a colleague necessarily wants to buy a ready-made wire, then I advise you to suggest external thickness, there is no certainty that it will translate into the thickness of the veins - but the chance is. You definitely should not buy flat cables.
  • #9 16625953
    gracjan55
    Level 36  
    Help: 315
    Rate: 244
    Buy yourself a blitzwolf cable, they are of good quality and have a length of 2.5m. Only price within 50 PLN.
  • #10 16627151
    Ture11
    Help: 573
    Rate: 1130
    Probably stupid and a bit offtop, but maybe the cheapest one came out to install an additional cigarette lighter socket into the car, closer to where the phone is located?
  • #11 16627168
    michalek510
    Rate: 27
    Look for cables Blitzwolf, Aukey, Nillkin. Just watch out for the fake allegro
The discussion revolves around the issue of charging a smartphone using a 5m MicroUSB cable connected to a 3x USB 2.4A car charger. The user reports that the long cable only maintains the battery percentage without charging, showing a current of 270mA, compared to 1710mA with a shorter, original cable. Responses indicate that the length of the cable significantly affects charging efficiency, with longer cables often leading to voltage drops and insufficient current delivery. Suggestions include checking the cable material (copper vs. steel) and considering reputable brands for replacement cables. Recommendations for quality cables include Blitzwolf, Aukey, and Nillkin, with a note to avoid counterfeit products.
