Scania R420 VIS Visibility Driver Replacement: Compatibility, Reprogramming & Error Display
Rzexxnik 19383 6
  • #1 16361646
    Rzexxnik
    Rate: 176
    Hello. I have a problem with the VIS visibility driver. I have to replace it. I would like to know, if I buy another one with numbers similar to mine, will I have to reprogram it or not? Will there be any errors on the display if I do not reprogram it?
  • #2 16362016
    EMAR92
    Rate: 57
    If the driver number is different from the original SDP3, it asks if you want to assign it.
    I had a car that had the driver replaced and it was ok, also before assigning it. But I don't know if it will always be like that.
  • #3 16363036
    Rzexxnik
    Rate: 176
    OK, thank you very much. Was the VIS driver also replaced in your case?
  • #4 16364161
    EMAR92
    Rate: 57
    I had the VIS replaced by the previous owner and it ran for several years without being assigned. But I am not able to say whether the translator put any or a car with a twin configuration.
  • #5 16365836
    Rzexxnik
    Rate: 176
    Ok. In that case, I will try to locate such a driver and replace it. If I mention it, I will share the information.
  • #6 16367378
    szaman108
    Help: 199
    Rate: 910
    It will work, but I think that assigning the driver is not known at what cost and problem, nowadays probably every other workshop dealing with repairing trucks has SDP3. When buying, try to get the part number and check if it is dedicated to yours. Scania has mixed up a bit with these drivers VIS, it was mainly about the output power for additional connections, you can check it all in Scania Multi.
  • #7 16377520
    Rzexxnik
    Rate: 176
    I replaced the driver with another used one, but the driver had to be assigned by SDP3 because the coordinator error was showing. After assigning everything was as it should be
The discussion revolves around the replacement of the VIS visibility driver in a Scania R420 truck. Users inquire about the compatibility of replacement drivers with similar part numbers and whether reprogramming is necessary. Responses indicate that if the driver number differs from the original, reprogramming via SDP3 may be required to avoid display errors. Some users report successful operation without reprogramming, while others experienced errors that were resolved after assignment. It is advised to verify part numbers and consider the specific configuration of the vehicle when sourcing a replacement driver.
