Seat AURA CD Radio - 24LC16B Memory: Calculating Correct Code (0146) Confirmation
max300 8013 6
  • #1 16365278
    max300
    Rate: 22
    Hello!
    Seat Aura CD radio
    24LC16B memory
    Could someone confirm if he calculates the code correctly: 0146
    I am not sure if I use the calculator correctly.
    • Seat.7z (786 Bytes) You must be logged in to download this attachment.
  • #2 16365335
    curdeballans
    Level 30  
    Help: 271
    Rate: 455
    0146 looks correct.
  • #3 16365355
    max300
    Rate: 22
    Thanks! I'll be able to check in the evening.
  • #4 16365383
    sq9fmc
    Help: 129
    Rate: 406
    WKC series CC calculates the code for this model correctly. The code is definitely what curdeballans wrote.
  • #5 16365432
    max300
    Rate: 22
    Or maybe someone will explain why the addresses: 18H, 19H, 1CH, 1DH are in red?
  • #6 16365466
    emik
    Help: 304
    Rate: 652
    In these Seatach (grundig) there is a different algorithm for counting the LB checksums, so the WKC calculator highlights them in red. Nevertheless, the code always computes correctly.
  • #7 16365488
    max300
    Rate: 22
    OK thanks!
The discussion centers around the calculation of the code for a Seat AURA CD radio utilizing a 24LC16B memory chip. A user seeks confirmation on the accuracy of the calculated code "0146." Responses indicate that the code is indeed correct, with one participant noting that the WKC series CC calculator accurately computes the code for this model. There is also a query regarding certain addresses highlighted in red, which is explained as a result of a different algorithm for calculating LB checksums in the Seatach (Grundig) radios, although the code remains valid.
