Seat Alana Car Radio Code: Incorrect 0481, Grundig WKC 4.0 Calculator Help Needed
Piasecki Bogusław 11583 4
  • #1 16965633
    Piasecki Bogusław
    Help: 158
    Rate: 318
    Hello. I need a code for the radio "Seat Alana CD". The customer says it is 0481 but cannot be SCAN. "Grundig WKC 4.0" calculator, I can't really use it. Input in attachment. Thank you in advance and best regards.
    • 24LC16B.bin (2 KB) You must be logged in to download this attachment.
    elektryk112
    Help: 176
    Rate: 239
    Hello. Radio model "6L0035156". If so, the code provided is correct, i.e. 0481.
    Yano_X
    Help: 72
    Rate: 84
    The client provided the correct code. If it were otherwise, you would have blocked the radio. In this case, the problem is related to the handling of the SCAN key. Press it several times for about 5s.
    Greetings.
  • #4 16966415
    adrian846
    Help: 5
    The radio must be turned on for at least one hour for the code entry window to appear. I encourage you to download the radio manual. Greetings.
