SB3A0 Diode Replacement in Funai TV Power Supply: Is BY228 a Good Fit?
cinko 5988 3
  • #1 16365464
    cinko
    Help: 18
    Rate: 207
    What diode replacement for SB3A0 works in the Tv FUnai power supply.
    Could BY228 be.
  • #2 16365501
    viayner
    Help: 1563
    Rate: 2052
    as the SB3A0 datasheet says it is a 3A / 100V Schottky diode. BY228 should be OK, it has a bit weaker current impulse resistance 50A vs 80A, it may be important depending on where it is placed.
    With Vishaya, maybe the EGPxx series depends on where it is located in the system.
  • #4 16383502
    cinko
    Help: 18
    Rate: 207
    Thank you for your help, I used the SR310 diode.
