FS ScenicView P19-2 – what is zener diode DZ920 between 18 V and 3.3 V?
Jan Leśniak 5220 1
  • #1 5363856
    Jan Leśniak
    Help: 27
    Rate: 13
    Hello, I would like to ask for help . Maybe someone has such a monitor and can give me a zener diode indication in the power supply - DZ920 - / it has completely burned - located at the power supply plug of the monitor electronics /
    Thank you for all the help - the diode is located between the voltage of 18 V and 3.3 V /
  • #2 5401143
    Jan Leśniak
    Help: 27
    Rate: 13
    I inserted a 7.5V diode, it gives 5V and 13V output voltage, and so it should be. Failure of the diode caused damaged elki on the main board. monitor, after replacing approx
    I close the subject
