- Internet Connectivity Issues: Huawei P9 Lite Cellular Data & Wi-Fi Interruptions
pawlo1141 4554 5
  • #1 16366962
    pawlo1141
    I have a problem with the phone Huawei P9 lite I do not work on the cellular data, although it shows me that I have LTE coverage and when I connect to wifi, it interrupts the internet from time to time. Is it the phone's fault or the router's and the operator's fault?
  • #2 16367008
    nutergsm
    Help: 1034
    Rate: 1665
    Make a hardreset. Set everything up again and see if anything has helped.
  • #3 16367016
    actin
    Help: 187
    Rate: 799
    Enter the network in which you work
  • #4 16367106
    pawlo1141
    I did the whole hard reset and nothing helped, and the network in which I have to play ended up charging my package and since then I do not have internet in cellular data, previously I did not use wifi.
  • #6 16367172
    pawlo1141
    I enabled it to show the speed in the notification bar and the speed reaches only 3K / Sa, wifi continues to work the same way and once it doesn't
    probably best to give in for warranty.
